Need fusses setting C code for 18f452
Sheeraz Khan
Member level 3
What are the best fusses setting for this code?
I need Configration bit setting for PIC 18f452 using PICpgm programmer
//                                                         Software License Agreement
// The software supplied herewith by Microchip Technology Incorporated
// (the “Company”) for its PIC® Microcontroller is intended and
// supplied to you, the Company’s customer, for use solely and
// exclusively on Microchip PIC Microcontroller products. The
// software is owned by the Company and/or its supplier, and is
// protected under applicable copyright laws. All rights are reserved.
//  Any use in violation of the foregoing restrictions may subject the
// user to criminal sanctions under applicable laws, as well as to
// civil liability for the breach of the terms and conditions of this
// license.
// THIS SOFTWARE IS PROVIDED IN AN “AS IS” CONDITION. NO WARRANTIES,
// WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED
// TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
// PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE COMPANY SHALL NOT,
// IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR
// CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
//        File:                18motr2.c
//        Written By:                Stephen Bowling, Microchip Technology
// This code implements a brush-DC servomotor using the PIC18C452 MCU.
// The code was compiled using the MPLAB-C18 compliler ver. 1.10
// The device frequency should be 20 MHz.
// The following files should be included in the MPLAB project:
//                18motr2.c                -- Main source code file
//                p18c452.lkr                -- Linker script file
//                The following project files are included by the linker script:
//                c018i.o                        -- C startup code
//                clib.lib                        -- Math and function libraries
//                p18c452.lib                -- Processor library
// Revision History
// 2/15/02 -- PID compensator calculation modified to support
// V2.00 of the MPLAB C-18 compiler.
// PID integral is now 32-bits to prevent integral overflow.
#include <p18c452.h>                                        // Register definitions
#include <stdlib.h>
#include <string.h>
#include <i2c.h>                                                // I2C library functions
#include <pwm.h>                                                // PWM library functions
#include <adc.h>                                                // ADC library functions
#include <portb.h>                                        // PORTB library function
#include <timers.h>                                        // Timer library functions
//Constant Definitions
#define        DIST        0                                                // Array index for segment distance
#define        VEL        1                                                // Array index for segment vel. limit
#define        ACCEL        2                                                // Array index for segment accel.
#define        TIME        3                                                // Array index for segment delay time
#define        INDEX        PORTBbits.RB0                // Input for encoder index pulse
#define        NLIM        PORTBbits.RB1                // Input for negative limit switch
#define        PLIM        PORTBbits.RB2                // Input for positive limit switch
#define        GPI        PORTBbits.RB3                // General purpose input
#define        MODE1        !PORTBbits.RB4                // DIP switch #1
#define        MODE2        !PORTBbits.RB5                // DIP switch #2
#define        MODE3        !PORTBbits.RB6                // DIP switch #3
#define        MODE4        !PORTBbits.RB7                // DIP switch #4
#define        SPULSE        PORTCbits.RC5        // Software timing pulse output
#define        ADRES        ADRESH                                // Redefine for 10-bit A/D converter
// Variable declarations
const rom char ready[] = "\n\rREADY>";
const rom char badcmd[] = "\n\rERROR!";
char inpbuf[8];                                                        // Input command buffer
unsigned char
eeadr,        // Pointer to EEPROM address
firstseg,        // First segment of motion profile
lastseg,        // Last segment of motion profile
segnum,        // Current executing segment
parameter,        // Index to profile data
i,        // index to ASCII buffer
comcount,        // index to input string
udata        // Received character from USART
struct {        // Holds status bits for servo
    unsigned            phase:1;                // Current phase of motion profile
    unsigned         neg_move:1;                // Backwards relative move
    unsigned                           motion:1;                // Segment execution in progress
    unsigned                   saturated:1;                // PWM output is saturated
    unsigned                  bit4:1;
    unsigned                             bit5:1;
    unsigned              run:1;                // Enables execution of profile
    unsigned             loop:1;                // Executes profile repeatedly
} stat ;
int
dtime,        // Motion segment delay time
kp,ki,kd,        // PID gain constants
vlim,        // Velocity limit for segment
mvelocity,        // Measured motor velocity
DnCount,        // Holds accumulated 'up' pulses
UpCount        // Holds accumulated 'down' pulses
union LNG
long l;
unsigned long ul;
int i[2];
unsigned int ui[2];
char b[4];
unsigned char ub[4];
union LNG
temp,                                                        // Temporary storage
accel,                                                // Segment acceleration value
error,                                                        // PID error value
integral,               // PID integral value
ypid,                                                        // Holds output of PID calculation
velact,                                                // Current commanded velocity
phase1dist                                        // Half of segment distance
long
position,                         // Commanded position.
mposition,                                        // Actual measured position.
fposition,                                        // Originally commanded position.
flatcount;                        // Holds the number of sample periods for which
                                                           // the velocity limit was reached in the first
                                                           // half of the move.
#pragma udata segdata1 = 0x0100
int segment1[12][4];                // Holds motion segment values in data memory.
int segment2[12][4];                //                                                 "
#pragma udata
// Function Prototypes
void servo_isr(void);                // Does servo calculations
void isrhandler(void);                // Located at high interrupt vector
void DoCommand(void);                // Processes command input strings
void Setup(void);                                // Configures peripherals and variables
void UpdPos(void);                        // Gets new measured position for motor
void CalcError(void);                // Calculates position error
void CalcPID(void);                        // Calculates new PWM duty cycle
void UpdTraj(void);                        // Calculates new commanded position
void SetupMove(void);                // Gets new parameters for motion profile
// Writes a string from ROM to the USART
void putrsUSART(const rom char *data);
// ExtEEWrite and ExtEERead are used to read or write an integer value to the
// 24C01 EEPROM
void ExtEEWrite(unsigned char address, int data);
int ExtEERead(unsigned char address);
// Interrupt Code
// Designate servo_isr as an interrupt function and save key registers
#pragma interrupt servo_isr save = PRODL,PRODH,temp
// Locate ISR handler code at interrupt vector
#pragma code isrcode=0x0008
void isrhandler(void)        // This function directs execution to the
{        // actual interrupt code
_asm
goto servo_isr
_endasm
#pragma code
// servo_isr()
// Performs the servo calculations
SPULSE = 1;        // Toggle output pin for ISR code
        // timing
UpdTraj();        // Get new commanded position
UpdPos();        // Get new measured position
CalcError();                                                        // Calculate new position error
CalcPID();
PIR1bits.TMR2IF = 0;                                        // Clear Timer2 Interrupt Flag.
SPULSE = 0;        // Toggle output pin for ISR code
}        // timing
// UpdTraj()
//        Computes the next required value for the next commanded motor
// position based on the current motion profile variables.  Trapezoidal
// motion profiles are produced.
void UpdTraj(void)
if(stat.motion && !stat.saturated)
   if(!stat.phase)                                        // If in the first half of the move.
      if(velact.ui[1] < vlim)           // If still below the velocity limit
         velact.ul += accel.ul;  // Accelerate
      else                              // If velocity limit has been reached,
         flatcount++;                                // increment flatcount.
      temp.ul = velact.ul;                        // Put velocity value into temp
        // and round to 16 bits
      if(velact.ui[0] == 0x8000)
              if(!(velact.ub[2] & 0x01))
                      temp.ui[1]++;
      else
      if(velact.ui[0] > 0x8000) temp.ui[1]++;
      phase1dist.ul -= (unsigned long)temp.ui[1];
      if(stat.neg_move)
              position -= (unsigned long)temp.ui[1];
      else
         position += (unsigned long)temp.ui[1];
      if(phase1dist.l <= 0)                // If phase1dist is negative
        // first half of the move has
              stat.phase = 1;                        // completed.
   else        // If in the second half of the move,
      {        // Decrement flatcount if not 0.
      if(flatcount) flatcount--;
                else
                if(velact.ul)                                        // If commanded velocity not 0,
                        velact.ul -= accel.ul;        // Decelerate
                        if(velact.i[1] < 0)
                                velact.l = 0;
                else        // else
                        if(dtime) dtime--;                // Decrement delay time if not 0.
                        else
                                stat.motion = 0;                // Move is done, clear motion flag
                                position = fposition;
                      temp.ui[1]++;
      else
      if(stat.neg_move)                                // Update commanded position
      else
        }        // END if (stat.motion)
else
        if(stat.run && !stat.motion)        // If motion stopped and profile
                {        // running, get next segment number
                if(segnum < firstseg) segnum = firstseg;
                if(segnum > lastseg)
                        segnum = firstseg;                // Clear run flag if loop flag not set.
                        if(!stat.loop) stat.run = 0;
                else
                        SetupMove();                                // Get data for next motion segment.
                        segnum++;                                        // Increment segment number.
// SetupMove()
// Gets data for next motion segment to be executed
if(segnum < 12)        // Get profile segment data from
        {        // data memory.
        phase1dist.i[0] = segment1[segnum][DIST];
        vlim = segment1[segnum][VEL];
        accel.i[0] = segment1[segnum][ACCEL];
        dtime = segment1[segnum][TIME];
else if(segnum < 24)
        phase1dist.i[0] = segment2[segnum - 12][DIST];
        vlim = segment2[segnum - 12][VEL];
        accel.i[0] = segment2[segnum - 12][ACCEL];
        dtime = segment2[segnum - 12][TIME];
phase1dist.b[2] = phase1dist.b[1];                // Rotate phase1dist one byte
phase1dist.b[1] = phase1dist.b[0];                // to the left.
phase1dist.b[0] = 0;
if(phase1dist.b[2] & 0x80)                                 // Sign-extend value
   phase1dist.b[3] = 0xff;
else
   phase1dist.b[3] = 0;
accel.b[3] = 0;        // Rotate accel one byte to
accel.b[2] = accel.b[1];                                        // the left
accel.b[1] = accel.b[0];
accel.b[0] = 0;
temp.l = position;
if(temp.ub[0] > 0x7f)                                                // A fractional value is left
        temp.l += 0x100;                                                        // over in the 8 LSbits of
temp.ub[0] = 0;        // position, so round position
        // variable to an integer value
position = temp.l;                                                        // before computing final move
        // position.
fposition = position + phase1dist.l;        // Compute final position for
        // the move
if(phase1dist.b[3] & 0x80)                                        // If the move is negative,
   stat.neg_move = 1;                                                // Set flag to indicate negative
   phase1dist.l = -phase1dist.l;                        // move.
else stat.neg_move = 0;                                                // Clear flag for positive move
phase1dist.l >>= 1;                                                        // phase1dist holds total
        // move distance, so divide by 2
velact.l = 0;                          // Clear commanded velocity
flatcount = 0;        // Clear flatcount
stat.phase = 0;        // Clear flag:first half of move
if(accel.l && vlim)
stat.motion = 1;        // Enable motion
// UpdPos()
// Gets the new measured position of the motor based on values
// accumulated in Timer0 and Timer1
void UpdPos(void)
// Old timer values are presently stored in UpCount and DnCount, so
// add them into result now.
mvelocity = DnCount;
mvelocity -= UpCount;
//  Write new timer values into UpCount and DnCount variables.
UpCount = ReadTimer0();
DnCount = ReadTimer1();
// Add new count values into result.
mvelocity += UpCount;
mvelocity -= DnCount;
// Add measured velocity to measured position to get new motor
// measured position.
mposition += (long)mvelocity << 8;
// CalcError()
// Calculates position error and limits to 16 bit result
temp.l = position;                                                        // Put commanded pos. in temp
temp.b[0] = 0;        // Mask out fractional bits
error.l = temp.l - mposition;                                        // Get error
error.b[0] = error.b[1];                                                        // from desired position and
error.b[1] = error.b[2];                                                        // shift to the right to discard
error.b[2] = error.b[3];                                                        // lower 8 bits.
if (error.b[2] & 0x80)                                                        // If error is negative.
        error.b[3] = 0xff;                                                        // Sign-extend to 32 bits.
        if(error.l < -32768)
                error.l = -32768;                                                // Limit error to 16-bits.
else        // If error is positive.
        error.b[3] = 0x00;
        if(error.l > 32767)
                error.l = 32767;                                                // Limit error to 16-bits.
// CalcPID()
// Calculates PID compensator algorithm and determines new value for
// PWM duty cycle
void CalcPID(void)
if(!stat.saturated)        // If output is not saturated,
   integral.l += error.l;  // modify the integral value.
// Calculate the PID compensator.
ypid.l = (long)error.i[0]*(long)kp + integral.l*(long)ki +
         (long)mvelocity*(long)kd;
if(ypid.ub[3] & 0x80)                                        // If PID result is negative
        if((ypid.ub[3] < 0xff) || !(ypid.ub[2] & 0x80))
                ypid.ul = 0xff800000;                        // Limit result to 24-bit value
else        // If PID result is positive
        if(ypid.ub[3] || (ypid.ub[2] > 0x7f))
                ypid.ul = 0x007fffff;                        // Limit result to 24-bit value
ypid.b[0] = ypid.b[1];                                        // Shift PID result right to
ypid.b[1] = ypid.b[2];                                        // get upper 16 bits.
stat.saturated = 0;                                                // Clear saturation flag and see
if(ypid.i[0] > 500)                                                // if present duty cycle output
        {        // exceeds limits.
        ypid.i[0] = 500;
        stat.saturated = 1;
if(ypid.i[0] < -500)
        ypid.i[0] = -500;
        stat.saturated = 1;
ypid.i[0] += 512;                                                        // Add offset to get positive
        // duty cycle value.
SetDCPWM1(ypid.i[0]);                                        // Write the new duty cycle.
//        Setup() initializes program variables and peripheral registers
void Setup(void)
firstseg = 0;                                                        // Initialize motion segment
lastseg = 0;                                                        // variables
segnum = 0;
parameter = 0;                                                        // Motion segment parameter#
i = 0;        // Receive buffer index
comcount = 0;                                                        // Input command index
udata = 0;        // Holds USART received data
stat.phase = 0;                                                // Set flags to 0.
stat.saturated = 0;
stat.motion = 0;
stat.run = 0;
stat.loop = 0;
stat.neg_move = 0;
dtime = 0;
integral.l = 0;
vlim = 0;
mvelocity = 0;
DnCount = 0;
UpCount = 0;
temp.l = 0;
accel.l = 0;
error.l = 0;
ypid.l = 0;
velact.l = 0;
phase1dist.l = 0;
position = 0;
mposition = 0;
fposition = 0;
flatcount = 0;
udata = 0;
memset(inpbuf,0,8);                   // clear the input buffer
// Setup A/D converter
OpenADC(ADC_FOSC_32 & ADC_LEFT_JUST & ADC_1ANA_0REF,
                        ADC_CH0 & ADC_INT_OFF);
OpenPWM1(0xff);                                // Setup Timer2, CCP1 to provide
        //        19.53 Khz PWM @ 20MHz
OpenTimer2(T2_PS_1_1 & T2_POST_1_10 & TIMER_INT_ON);
SetDCPWM1(512);                                // 50% initial duty cycle
EnablePullups();           // Enable PORTB pullups
PORTC = 0;                                                // Clear PORTC
PORTD = 0;                                                //        Clear PORTD
PORTE = 0x00;                                        //        Clear PORTD
TRISC = 0xdb;                                        //
TRISD = 0;                                                // PORTD all outputs.
TRISE = 0;                                                // PORTE all outputs.
// Setup the USART for 19200 baud @ 20MHz
SPBRG = 15;                                                // 19200 baud @ 20MHz
TXSTA = 0x20;                                        // setup USART transmit
RCSTA = 0x90;                                        // setup USART receive
putrsUSART("\r\nDC Servomotor By ~*~ RS Electronic ~*~");
putrsUSART(ready);
OpenI2C(MASTER,SLEW_OFF);        // Setup MSSP for master I2C
SSPADD = 49;                               // 100KHz @ 20MHz
kp = ExtEERead(122);                        // Get PID gain constants
ki = 0;                                                        // from data EEPROM
kd = ExtEERead(126);
TMR0L = 0;                                                // Clear timers.
TMR0H = 0;
TMR1L = 0;
TMR1H = 0;
OpenTimer0(TIMER_INT_OFF & T0_16BIT & TIMER_INT_OFF & T0_EDGE_RISE &
                                T0_SOURCE_EXT & T0_PS_1_1);
OpenTimer1(TIMER_INT_OFF & T1_SOURCE_EXT & T1_16BIT_RW & TIMER_INT_OFF
                                & T1_PS_1_1 & T1_SYNC_EXT_ON & T1_OSC1EN_OFF );
// Load motion profile data for segments 1 through 12 from
// data EEPROM
for(segnum=0;segnum < 12;segnum++)
        for(parameter=0;parameter < 4;parameter++)
                eeadr = (segnum << 3) + (parameter << 1);
                segment1[segnum][parameter] = ExtEERead(eeadr);
segment2[0][DIST] = 29500;                        // Motion profile data for segments
segment2[0][VEL] = 4096;                        // 13 through 24 are loaded into RAM
segment2[0][ACCEL] = 2048;                        // from program memory
segment2[0][TIME] = 1200;
segment2[1][DIST] = -29500;
segment2[1][VEL] = 1024;
segment2[1][ACCEL] = 512;
segment2[1][TIME] = 1200;
segment2[2][DIST] = 737;
segment2[2][VEL] = 4096;
segment2[2][ACCEL] = 2048;
segment2[2][TIME] = 1200;
segment2[3][DIST] = 737;
segment2[3][VEL] = 4096;
segment2[3][ACCEL] = 2048;
segment2[3][TIME] = 1200;
segment2[4][DIST] = 738;
segment2[4][VEL] = 4096;
segment2[4][ACCEL] = 2048;
segment2[4][TIME] = 1200;
segment2[5][DIST] = 738;
segment2[5][VEL] = 4096;
segment2[5][ACCEL] = 2048;
segment2[5][TIME] = 1200;
segment2[6][DIST] = -2950;
segment2[6][VEL] = 1024;
segment2[6][ACCEL] = 128;
segment2[6][TIME] = 1200;
segment2[7][DIST] = 2950;
segment2[7][VEL] = 256;
segment2[7][ACCEL] = 64;
segment2[7][TIME] = 1200;
segment2[8][DIST] = -2950;
segment2[8][VEL] = 4096;
segment2[8][ACCEL] = 512;
segment2[8][TIME] = 1200;
segment2[9][DIST] = 29500;
segment2[9][VEL] = 1024;
segment2[9][ACCEL] = 512;
segment2[9][TIME] = 1200;
segment2[10][DIST] = 29500;
segment2[10][VEL] = 2048;
segment2[10][ACCEL] = 512;
segment2[10][TIME] = 1200;
segment2[11][DIST] = 29500;
segment2[11][VEL] = 4096;
segment2[11][ACCEL] = 1024;
segment2[11][TIME] = 1200;
if(MODE1)        // Check DIP switches at powerup
   stat.loop = 1;                                                // If SW1 is on, set for loop mode
if(MODE2)        // If SW2 is on, execute
   {        // segments 12 and 13
   firstseg = 12;
   lastseg = 13;
   segnum = 12;
        stat.run = 1;
else if(MODE3)                                                        // If SW3 is on, execute
   {        // segments 14 through 18
        firstseg = 14;
   lastseg = 18;
   segnum = 14;
        stat.run = 1;
else if(MODE4)                                                        // If SW4 is on, execute
   {        // segments 18 and 19
        firstseg = 18;
   lastseg = 19;
   segnum = 18;
   stat.run = 1;
INTCONbits.PEIE = 1;                                        // Enable peripheral interrupts
INTCONbits.GIE = 1;                                        // Enable all interrupts
// main()
void main(void)
Setup();        // Setup peripherals and software
        // variables.
while(1)                                    // Loop forever
   ClrWdt();                                                        // Clear the WDT
   ConvertADC();                                                // Start an A/D conversion
   while(BusyADC());                                        // Wait for the conversion to complete
        PORTD = 0;                                                        // Clear the LED bargraph display.
        PORTE        &= 0x04;                                                //                                                "
        if(ADRES > 225)
                PORTE |= 0x03;                                        // Turn on 10 LEDS
                PORTD = 0xff;
        if(ADRES > 200)
                PORTE |= 0x01;                                        // Turn on 9 LEDS
                PORTD = 0xff;
        else if(ADRES > 175) PORTD = 0xff;        // Turn on 8 LEDS
        else if(ADRES > 150) PORTD = 0x7f;        // 7 LEDS
        else if(ADRES > 125) PORTD = 0x3f;        // 6 LEDS
        else if(ADRES > 100) PORTD = 0x1f;        // 5 LEDS
        else if(ADRES > 75) PORTD = 0x0f;        // 4 LEDS
        else if(ADRES > 50) PORTD = 0x07;        // 3 LEDS
        else if(ADRES > 25) PORTD = 0x03;        // 2 LEDS
        else if(ADRES > 0) PORTD = 0x01;                // 1 LED
        if(PIR1bits.RCIF)        // Check for USART interrupt
           switch(udata = RCREG)
              case ',':        DoCommand();                                // process the string
                          i = 0;                                                // clear the buffer index
                          comcount++;                                        // increment comma count
                          TXREG = udata;                                // echo the character
                          break;
              case 0x0d:  DoCommand();                                // process the string
                          comcount = 0;                                // clear comma count
                                                        segnum = 0;                                        // clear segment number
                                                        parameter = 0;                                // clear paramater
                                                        putrsUSART(ready);                // put prompt to USART
                          break;
              default:    inpbuf[i] = udata;                // get received char
                          i++;                                                        // increment buffer index
                          if(i > 7)                                        // If more than 8 chars
                             {                                                        // received before getting
                             putrsUSART(ready);         // a <CR>, clear input
                             memset(inpbuf,0,8);        // buffer
                             i = 0;                                        // the buffer index
                          else TXREG = udata;                 // echo character
                          break;                                                //
         }        //end switch(udata)
            }        //end if(RCIF)
    }        //end while(1)
// DoCommand()
// Processes incoming USART data.
if(comcount == 0)                // If this is the first parameter of the input
        {                                                // command...
        switch(inpbuf[0])
                case 'X':        parameter = DIST;                // Segment distance change
                                                break;
                case 'V':        parameter = VEL;                // Segment velocity change
                                                break;
                case 'A':        parameter = ACCEL;        // Segment acceleration change
                                                break;
                case 'T':        parameter = TIME;                // Segment delay time change
                                                break;
                case 'P':        parameter = 'P';                // Change proportional gain
                                                break;
                case 'I':        parameter = 'I';                // Change integral gain
                                                break;
                case 'D':        parameter = 'D';                // Change differential gain
                                                break;
                case 'L':        parameter = 'L';                // Loop a range of segments
                                                break;
                case 'S':        stat.run = 0;                        // Stop execution of segments
                                                break;
                case 'G':        parameter = 'G';                // Execute a range of segments
                                                break;
                case 'W':   if(PORTEbits.RE2)                // Enable or disable motor
                                                        {                                                // driver IC
                                                        putrsUSART("\r\nPWM On");
                                                        PORTEbits.RE2 = 0;
                                                else
                                                        putrsUSART("\r\nPWM Off");
                                                        PORTEbits.RE2 = 1;
                                                break;
           default:    if(inpbuf[0] != '\0')
                          putrsUSART(badcmd);
                       break;
else if(comcount == 1)                // If this is the second parameter of the
        {        // input command.
        if(parameter < 4) segnum = atob(inpbuf);
        else
        switch(parameter)
                case 'P':   kp = atoi(inpbuf);                        // proportional gain change
                            ExtEEWrite(122, kp);                        // Store value in EEPROM
                            break;
                case 'I':   ki = atoi(inpbuf);                        // integral gain change
                            ExtEEWrite(124, ki);                        // Store value in EEPROM
                            break;
                case 'D':   kd = atoi(inpbuf);                        // differential gain change
                            ExtEEWrite(126, kd);                        // Store value in EEPROM
                            break;
                case 'G':        firstseg = atob(inpbuf);
                                                break;
        // Get the first segment in
        // the range to be executed.
                case 'L':        firstseg = atob(inpbuf);
                                                break;
                default:    break;
else if(comcount == 2)
        if(!stat.run)                                                        // If no profile is executing
                if(parameter < 4)                                        // If this was a segment parameter
                        {        // change.
                        if(segnum < 12)
                                // Write the segment paramater into data memory
                                segment1[segnum][parameter] = atoi(inpbuf);
                                // Compute EEPROM address and write data to EEPROM
                                ExtEEWrite(eeadr, segment1[segnum][parameter]);
                                // Write segment parameter data into data memory
                                segment2[segnum - 12][parameter] = atoi(inpbuf);
                else switch(parameter)
                        case 'G':        lastseg = atob(inpbuf);                                // Get value for
                                    segnum = firstseg;                                        // last segment.
                                                        stat.loop = 0;
                                                        stat.run = 1;                                                        // Start profile.
                                                        break;
                        case 'L':        lastseg = atob(inpbuf);                                // Get value for
                                                        stat.loop = 1;                                                        // Enable looping
                                                        break;
                        default:    break;
// ExtEEWrite()
// Writes an integer value to an EEPROM connected to the I2C bus at
// the specified location.
union
char b[2];
int i;
temp;
char error, retry;
temp.i = data;
error = 0;
retry = 10;        // Poll the EEPROM up to 10 times
do
        error = EEAckPolling(0xA0);
        retry--;
        } while(error && retry > 0);
retry = 10;        // Attempt to write low byte of data
do        // up to 10 times
        error = EEByteWrite(0xA0, address, temp.b[0]);
        retry--;
do
        retry--;
retry = 10;        // Attempt to write high byte of data
        error = EEByteWrite(0xA0, address + 1, temp.b[1]);
        retry--;
// ExtEEWrite()
// Reads an integer value from an EEPROM connected to the I2C bus at
union
char b[2];
int i;
data;
union
char b[2];
int i;
temp;
char retry;
retry = 10;        // Attempt to read low byte of data
        temp.i = EERandomRead(0xA0, address);
        retry--;
        } while(temp.b[1] && retry > 0);
if(temp.b[1]) data.b[0] = 0;                // Make read result 0 if error
else data.b[0] = temp.b[0];                // Otherwise get the low byte of data
retry = 10;        // Attempt to read high byte of data
        temp.i = EERandomRead(0xA0, address + 1);
        retry--;
if(temp.b[1]) data.b[1] = 0;                // Make read result 0 if error
else data.b[1] = temp.b[0];                // Otherwise get the high byte of data
return data.i;
// putrsUSART()
// Writes a string of characters in program memory to the USART
        do
                while(!(TXSTA & 0x02));
                TXREG = *data;
        } while( *data++ );
Open Configure>Configuration Bits
Here You Can Configure Configuration bits
but You Must Know what Setting You May need depending upon your application
