Re: I-Logix Rhapsody c++
Hello,
Rhapsody will help you "model" a software system which you want to write in C/C++/Java. Since you say SystemC, I think you want to Design a HW/SW system or create an Verification environment. If you want to use Rhapsody, you will have to understand the followign topics
-- C++, if you know SystemC then its obvious that you know C++
-- Modeling concepts, which is about Software design with UML. (This is nothing related to your HW modeling, design or verification)
Since you model your HW/SW System in SystemC, you develop the code in SystemC. Before you develop the code in SystemC, you may use Rhapsody to express your design. This will help you to view your design, work with your design, change your design. Once you have some UML-Design, as a description of your HW/SW system you can direclty code using SystemC. But you will have to understand UML and Rhapsody usage.
Kars
