need driven motor by 8051
diver143
Newbie level 6
Newbie level 6
need driven motor circuit by the car battery 12vdc.
that is a
Car motor's window
useing the 8051
thankz
Do you need variable speed, overcurrent detection, both sens of rotation?
no just up and down
regards,
diver143
The simplest way is to use 2 relays each with 1 NO and 1 NC contacts. The relays are driven by the 8051 using optocouplers follow by a npn transistor(my option). The power schematic is
V+ --- R1NO --- Motor---- R2NC - gnd
gnd -- R1NC--| |---R2NO - V+
If you close relay1, motor will rotate one sense. Closing relay2 will rotate the other sense
Another option is to use instead of relays 4 power transistors (or 2 transistor and 2 diodes) in a H configuration.
Fuses are necessary to be use.
THANK YOU SO MUCH.
I'LL SEE :lol:
You can use transistor bridge and drive it by digital ports.
______________________ +12
PNP PNP
-------(M)---------
NPN NPN
--- GND
If u need to chane a speed use just PWM and that's it.
Lm
Sorry,
drawwing by chars does not work as I expected.
Transistors T1 and T2 have to switched on at the same time for one direction. To change direction in oposit way T3 and T$ have to be switched on at the same time.
Do not forget to use PWM if u want to control speed
Lm
Hi
You can use L293 or L272 for smaller motors
Take a look at www.st.com for applications and data sheets,
also Allegro and NJRC for integrated components.
bye 8)
