Need code for interface with lcd hitachi
vinodjprakash
Newbie level 2
avr and ke*il
hi
Added after 1 minutes:
i need source code interface 8515 atmel with lcd hitachi
Do you need source in Assembler or in C?
seach for avrlib on google it is a nice one. but it use with winavr
in my opinion, u should write yoursefl in C, use CodevisionAVR compiler(compiler help u alots). it is easier and u can get much experiencies. if u dont want to do that, next time i will post LCD source code.
And if u did not have compiler, so it is here
Added after 17 minutes:
Here is code for textLCD,
// LCD function
// Version 1.0 Sept 2000
// Sylvain Bissonnette
// I N C L U D E
#include <io2313.h>
// D E F I N E
// User dependent BEGIN
#define D7 0x01
#define D6 0x02
#define D5 0x04
#define D4 0x08
#define E 0x10
#define RW 0x20
#define RS 0x40
#define LCDPIN (*(volatile unsigned char *)0x36) // PIN register
#define LCDDDR (*(volatile unsigned char *)0x37) // Data Direction Register
#define LCDPORT (*(volatile unsigned char *)0x38) // PORT
// User dependent END
// P R O T O T Y P E
void InitLCD(void);
void ClrLCD();
void GotoXY(unsigned char,unsigned char);
void WriteStrLCD(char *);
void WriteStrLCDConst(const char *);
void WriteByteLCD(char);
void WriteLCD(unsigned char,unsigned char);
void Delay_50us(int Delay);
// M A I N
void main(void)
InitLCD();
ClrLCD();
GotoXY(5,1);
WriteStrLCD("Test\0");
while(1);
// LCD Code
Name: void ClrLCD(void)
Description: Clear the LCD
Input: none
Output: none
Misc:
void ClrLCD()
WriteLCD(0,0x01); // Clear display
Delay_50us(50);
Name: GotoXY(unsigned char x, unsigned char y)
Description: Position cursor on the LCD at X & Y location
Input: X -> X position on the LCD
Y -> Y position on the LCD
Output: none
Misc:
void GotoXY(unsigned char x,unsigned char y)
unsigned char address;
x--;
if (y > 1) address = 64 + x;
else address = x;
WriteLCD(0,address | 0x80);
Description: Write a byte on the LCD at cursor position
Input: byte
Output: none
Misc:
void WriteByteLCD(char byte)
char tmp;
tmp = byte & 0xf0;
tmp = tmp >> 4;
tmp += 0x30;
if (tmp > 0x39) tmp += 0x07;
WriteLCD(1,tmp);
tmp = byte & 0x0f;
tmp += 0x30;
WriteLCD(1,tmp);
Name: void WriteStrLCD(char *ptr)
Description: Write a string from RAM on the LCD
Input: string pointer
Output: none
Misc:
unsigned char i;
for (i=1;i<41;i++)
if (*ptr == 0x00) break;
WriteLCD(1,*ptr);
*ptr++ = 0x00;
Name: void WriteStrLCDConst(const char *ptr)
Description: Write a constant string on the LCD
Output: none
Misc:
unsigned char i;
for (i=1;i<41;i++)
WriteLCD(1,*ptr++);
Name: void WriteLCD(unsigned char rs, unsigned char ch)
Description: Write a byte in rs of the LCD
Input: rs -> Register select
ch -> byte to write
Output: none
Misc:
void WriteLCD(unsigned char rs,unsigned char ch)
unsigned char Stat;
Stat = LCDPIN & 0x01;
PORTB = Stat;
if ((ch & 0x80) == 0x80) PORTB |= D7;
if ((ch & 0x40) == 0x40) PORTB |= D6;
if ((ch & 0x20) == 0x20) PORTB |= D5;
if ((ch & 0x10) == 0x10) PORTB |= D4;
if (rs == 1) PORTB |= RS;
PORTB |= E;
PORTB &= ~E;
PORTB = Stat;
if ((ch & 0x08) == 0x08) PORTB |= D7;
if ((ch & 0x04) == 0x04) PORTB |= D6;
if ((ch & 0x02) == 0x02) PORTB |= D5;
if ((ch & 0x01) == 0x01) PORTB |= D4;
PORTB |= E;
PORTB &= ~E;
Delay_50us(1);
Name: void Delay_50us(int Delay)
Description: Delay of 50 us with a 4Mhz resonator
Input: Delay X x 50us
Output: none
Misc:
int i,j;
for (i=0;i<Delay;i++)
for (j=1;j<20;j++);
asm("WDR");
Name: void InitLCD(void)
Description: Initialize LCD in 4bit mode
Input: none
Output: none
Misc:
void InitLCD(void)
LCDDDR = D7 + D6 + D5 + D4 + E + RS + RW;
LCDPORT = !(D7 + D6 + D5 + D4 + E + RS + RW);
Delay_50us(340);
LCDPORT = (D5 + D4); // Function Set 8 bit 3 time
LCDPORT |= E;
LCDPORT &= ~E;
Delay_50us(100);
LCDPORT |= E;
LCDPORT &= ~E;
Delay_50us(100);
LCDPORT |= E;
LCDPORT &= ~E;
Delay_50us(100);
LCDPORT = D5; // Function Set 4 bit
LCDPORT |= E;
LCDPORT &= ~E;
Delay_50us(100);
WriteLCD(0,0x28); // 2 line
WriteLCD(0,0x0c); // Display ON Cursor OFF Blink OFF
Delay_50us(50);
WriteLCD(0,0x06); // Cursor INC Shift OFF
