[PIC] need code for dcmotor control with 16f877a in PIC C compiler
kathi saiprathap reddy
Newbie level 3
Newbie level 3
i tried this code in pic c compiler but it shows an error with motor.c can any one help me out of this code;
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
#include <16f877a.h>
#use delay(clock=20M)
#fuses NOWDT,PROTECT,HS
#include <motor.c>
Void main()
unsigned int i, value, temp,gas;
output_high(pin_d2);
output_high(pin_d3);
delay_ms(500);
output_low(pin_d2);
output_low(pin_d3);
delay_ms(500);
delay_ms(500);
output_low(pin_d2);
output_low(pin_d3);
while(1)
      for(i=0;i<=10;i++)
       set_adc_channel( 0 );
      delay_ms(50);
      value = read_adc();
      temp = value*2.5;
      motor_forward();
      output_low(pin_d2);
      output_low(pin_d7);
      delay_ms(500);
      if(input(pin_b0))
      motor_right();
      output_low(pin_d3);
      output_low(pin_d7);
      else if (temp > 50 )
      output_high(pin_d7);
      else
      output_low(pin_d2);
      output_low(pin_d7);
please tell me how to write a code for motor in PIC c compiler.
you don't appear to have included the code for motor.c
what compiler are you using?
note that
Void main()
should be
int main(void)
