Im building a neon sign tesla coil and I don't want residential mains to ring from the gizmo. Will this prevent a decent amount of noise noise from going back into the mains?
Is this a topology with two transformers? Then the first transformer carries mains AC, while the second transformer carries high frequency AC (ringing). So the first transformer is probably a large Henry value which readily passes mains frequency AC, while presenting high impedance to high frequency AC. Therefore it's unlikely you'll get high frequency ringing in your house wiring.
