SoCalMacDude
I'm using a DTMF Decoder kit from Ramsey Electronics
to sense touch tones from an audio channel. I used it to drive relays to trigger pneumatic solenoid valves. Apparently the EMF from the coil turning off was blowing the big chip in the kit.
I have a new circuit design, replacing the mechanical relays with optoisolators triggering solid state circuitry (FET) to power the coils. When the TT7 kit's DTMF decoder 5V output pin goes low, the signal is sent through a 30ft. Cat5 cable to the optoisolater, which triggers the IRF830 FET.
My question is that I am concerned that the snubber circuit in this schematic may not be enough to protect everything. I was reading that a good strategy is to channel the energy to a capacitor, then discharge it through a resistor.
I'm not sure how to do that, or if it is best, or what values of components would work.
Here's my current circuit design. Any help would be much appreciated:
