NCSIM ddr2_controller post synthesis simulation - setup time warnings
Mahesh Shinde
I am running ddr2_controller post synthesis simulation using 45nm technology. I am getting setup time violation for one register, but I am not getting same timing violation for other registers. In same always block, I have assigned values to these registers. What could be the problem.
here is the screenshot of the warning
And here is the code,
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
always @(posedge fStrobe)
     case (count)
       0: r0 <= din;
       1: r2 <= din;
       2: r4 <= din;
       3: r6 <= din;
     endcase // case(counter)
   always @(negedge fStrobe)
     case (count)
       0: r1 <= din;
       1: r3 <= din;
       2: r5 <= din;
       3: r7 <= din;
// Read data
   always @ (r0 or r1 or r2 or r3 or r4 or r5 or r6 or r7  or readPtr)
     begin
        case (readPtr)
          3'b000: dout <= r0;
          3'b001: dout <= r1;
          3'b010: dout <= r2;
          3'b011: dout <= r3;
          3'b100: dout <= r4;
          3'b101: dout <= r5;
          3'b110: dout <= r6;
          3'b111: dout <= r7;
          default: dout <= r0;
        endcase // case (readPtr)
     end
It is very much possible to get a violation only on r1 and not on others. The fanout at DIN seems to be high. Can you try replicating DIN?
I tried replication, but still I am getting 'XX' result in r1 and r3 registers, rest of them are working properly. Till now I tried changing counter, even used gray counter, tried different logic using case statements, but still facing the problem. Dont know how to solve the r1, r3 register prob
Because of setup violations, r1 and r3 need not settle at X. It will be restored to a stable value. That is the way I suppose simulation tools handle this. I think there is some other issue here like multiple drive.You can run at a lower frequency to avoid these violations and check whether you are getting the same error.
