SherpaDoug
Full Member level 2
- Joined
- Jun 21, 2011
- Messages
- 149
- Helped
- 28
- Reputation
- 56
- Reaction score
- 28
- Trophy points
- 1,308
- Location
- Cape Cod, USA
- Activity points
- 2,260
I need a transformer or maybe a waveguide device that can couple 2.4GHz WiFi RF but block DC and 60Hz traveling on the shield. My radio circuitry ground is connected to seawater but my antenna is at the top of a steel mast and the mast is at local power utility AC neutral which can be several volts from seawater potential. Any connection from the mast to my coax shield or antenna ground plane causes big galvanic corrosion issues.
I looked for a "coax isolator" but that is something else entirely. A "DC block" only blocks the center conductor. If I knew what it is called I am sure I could buy one somewhere.
Thanks
Thanks
