N-bit ADC vams model
atulkulkarni
Newbie level 5
Newbie level 5
N bit Adc vams model
I am modelling a 12 bit ADC in vams.
The input range is 0.3 to 1.5V. i.e 0.3 = 000'H and 1.2V = FFF'H.
Need your help in selecting midpoint values
max= 1.5;
min=0.3
fullscale = max-min;
midpoint = fullscale/2.0;
This logic doesnt work.
Re: N bit Adc vams model
In case "midpoint" refers to the voltage level between min and max, I suggest
midpoint = (min + max)/2.0, or 0.9 V
analog
begin
V(VREF)<+ 0.7 + (TRIM * 0.0266667);
max_1=V(VREF) + 0.6;
min_1=V(VREF) - 0.6;
//	min_1=0;
fullscale_1=max_1+min_1;
midpoint1=fullscale_1/2.0;
end
always@( posedge (CLK_IN) or !(fault_avdd) )
begin
//if (!(fault_avdd))
//	begin
sample1=V(VIN);
//sample1=sample1-dummy;
	$display("INSIDE LOOP");
		for (i=0;i<`BITS;i=i+1)
		begin
		if(sample1 >= midpoint1)
		begin
		V_DOUT[`BITS-1-i]=1;
		sample1=sample1-midpoint1;
		$display("VALUE OF Sample inside if %f",sample1);
		$display("VALUE OF MIDPOINT inside if %f",midpoint1);
		$display("VALUE OF DUMMY %f", dummy);
		$display("VALUE OF MAX %f", max_1);
		end
		else
		begin
		V_DOUT[i]=0;
		$display("VALUE OF Sample inside else %f",sample1);
		$display("VALUE OF MIDPOINT inside else %f",midpoint1);
		end
		sample1 = 2.0*sample1;
		end
//	end
	if (fault_avdd)
	begin
	begin
	V_DOUT[i]=0;
	end
	end
end
VREF keeps on changing based on TRIM bits
fullscale should be "max - min", but as long as you don´t use the value for other calculation it is OK.
The midpoint calculation is correct.
Klaus
The calculation seems to mix absolute and relative voltage levels, which might cause confusion and unexpected results.
It's difficult to guess the meaning of the code without knowing the related hardware.
