I am working on a project to charge my cell phone while I am riding my bike. I have a small bike dynamo that outputs 15 vac at about 6w (obviously very dependent on speed). This is fed into a full bridge rectifier (4-diodes), then through a shunt capacitor to smooth the voltage. this is then fed through a voltage regulator (LM 309). This generates 5vdc which is fed into the power pins of a usb port (the data pins are shorted together to comply with usb charging standards). Unfortunately when I plug my phone in it reads that it is charging, but does not actually charge.
I feel that this is because the output current is too low. I get a reading of about 350 mA and I think 500 is required to charge. I was thinking about putting a 2:1 transformer before the rectifier to boost the current and drop the voltage, and not burn off so much energy in the rectifier. I thought this might work:
**broken link removed**, but I am not sure I am even on the right track.
If someone could give me their opinion that would be great.
i know that I probably should be going with something more efficient, but for a switched rectifier you need to design the controller, and I was hoping to just keep it simple.
