my project works in Protous and don't work on Board
bas_90
Member level 1
Member level 1
my project works in Protous and don't work on breadboard
"Code + Des. + Hex. file" in Attachments
Help Me Plz Cuz I'm Really Tired :(
  • Hello World.rar
i will try now , thnx alot :) :)
LCD Don't Show anything :(
how can test LCD if it Okay or not ?!
thnx ..
Try to put a trimpot or potentiometer into LCD VEE power rail (like example).
Where the crystal osc??? Edit:(It should be as close to mcu)
Where the MCLR pull up???
Check all connections!!!
Edit: Put too a capacitor 100nF decouple (It should be as close to mcu VCC power rail)
seems you have wiring issues, you have to check all connections (like what nagkiller told u)
try his schematic .
hello
I suggest you to place 33pF capacitors to both lead of crystal.if you don't get what am i telling then try to googling...let me expalinn you in steps
(1) Check power supply of LCd as well as also of uC. it shold be 5V
(2) Check clock circuits i dont know how to check crystal but mainly is is not damaged....you can check wiring of it and by physically damaged signs.
(3) Check connections of LCd and uC.
(4) Check reset circuit
(5) It is necessary to place some delay in programming while interfacing LCD so just check your software....
(5) If everything is a ok then replace LCD
Hello , it's working Okay now :)))) thnx all ^_^
but now i have a small problem ... when it working in 5v .. Lighting of words in pale
after change 5v to Battery (8.5v) .. It's Perfect
now i complete my work in 8.5v or what ?!
@jayanth .. I tried, but to no avail ... what can i do now ?! :)
but it's working fine ...
before last test i'm changed the Res. connected to PIN1(uC) to 33k not 10k and Crystal to 4MHz not 20 MHz
probably this make a pale words in LCD or what ?!
