TurboPC
I have a design with regular ICs and FPGAs. They are all rated from 0 to 70 degree Celsius. Although I know what will happen if the temperature is too high, I wonder what is the effect of the cold on them.
What happens if I powerup the board and the temperature is below 0 degrees? Will the chips die or the junctions break?
Is there better chances if the board is powered up at room temperature and then go in a very cold environment?
Thanks for your help.
TurboPC
TurboPC
