My chip is burned down, need your help!
welton
Newbie level 6
Hi all,
My chip is burned down, it was burned after a long operation during tests. It's a 1A charger IC. I have tested several tens chips, but 2 were damaged. I saw Supply current is current limited by my setting(2A), VBAT current is ~30mA, and then chip was burned down.
1) Could you help me to figure out what're the causes in your experience?
2) Will latch-up result in this condition? When the circuit might cause latch-up condition, will all chips fabricated latched-up?
3) When lath-up condition happens in some chip, will this chip be damaged and never be powered up or never works?
Thanks for your help.
1. Check layout of your pcb-board. Improper layout can lead to voltage or current spikes.
2. Check inductor for saturation.
3. Check temperature of chip and other components
4. Find latch-up current for every pin of your chip. It must be at least 100 mA
5. Ask your foundry results of OLT (operation life test) for every element of technology
Hi fragment,
I am sorry I didn't describe in detail.
The situation is, when I was doing short circuit TESTs, the IC is biased at trickle condition.
1) VIN=+5V, VBAT=0V(in trickle charge condition), TEMP=1.5V(normal condtion).
2) I used a metal wire to short VBAT and TEMP, there is a large current(2A, current limited by 1.5V supply) flow into E-load. This should be normal condition because E-load should sink the current.
3) When I try to touch on and off the metal wire(to let the VBAT and TEMP switch between short and open condition), IC was burned down. I de-cap the IC and found the damaged place is near the Source of the power PMOS.
I have no idea why it happened because during normal operations, the current is more then 1A, and the chip works well.
Please help me.
Thank you very much!
I don't see, how the issue can be discussed seriously without knowing the device circuit and the test setup.
