i dunno why my adapter is always giving 3v more then in its operating mode ...if i operate on 3v it gives 6v ..i i operate in 6v it gives 9v n so on ...wats wrong guys ...checked internal circuit ...but couldnt understand anything
Simply that the label next to the switch on my power adaptor was put in the wrong place. It may not be your problem, but problems are sometimes not complex or electronic.
hi,
an adapter is based on the principle of mutual induction..i mean to say here the use of transformer inside it...u have a varyin voltage adapter ..means the number of coils arrangement in the transformer must have roled in this matter!!!!
u have got a progressive three voltage increase..i doubt,this might be the cause...the output is differnt in the same pattern..
yep i think same now..but may be there is a problem similar as working of a potentiometer.the internal portion of the changing part might be the problem???
its seem confusing!!
