Multiplying integer variables in verilog
hassanzia
Junior Member level 3
Is it possible to multiply integer variable in a verilog for loop?
example
integer i,j = 0;
for (i=0; i<10; i=i+1)
j = 16 * (i+1);
yes, should be possible, but in your case, the answer is just a constant.
Its giving a syntax error whenever I try to do this. (HDLCompiler : 806, if that helps)
why not post the actual code and the actual error? or read what the error says and fix it? Syntax errors are normally self explanitory.
