Multiplexing two SPI Master
wat007
Junior Member level 3
Is it possible to switch two master SPI lines using Quad 2:1 multiplexer like (74HC257)? I want my two Master devices to access a single SPI slave (Flash). SPI speed is 4MHz. Please see attached schematics.
The reason for this is that, I have an MP3 module (master2) which already has a flash that I want my MCU (master1) to access the data from. I don't have control on SPI lines of MP3 (Master2). Schematics.jpg
Your multiplexing should work.
MISO doesn't need to be switched.
I'd add a pullup resistor at !CS of flash.
You need an arbitration before switching MUX to prevent data corruption.
Klaus
Thanks KlausST, I will post my results soon.
