polus
Junior Member level 2
multiple seven segment
I have a project that requires 12 of these. Has anyone used this many in a project before and whats the cheapest/best way of controlling them all?
Presumably Id need a port (8 bits) for the different LED's within the displays and then 12 display select lines? But how to keep state?
I have found an alternative in the fiorm of the MAX6955 which looks like a great IC and will allow the use of a cheaper MCU (with less IO) but the MAX IC is expensive.
MAX6955 Datasheet:
Any tips or pointers would be very much appreciated!
MAX6955 Datasheet:
