rajesh0therascal
Newbie level 3
- Joined
- May 22, 2013
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,317
I have a 16 MHz clock on board. I need 250 Hz, 1/3 Hz and 1/21 Hz clocks for inner logic circuits to work.. I have derived 250 Hz clock in synchronous manner using clock enable. So now can I use that 250 Hz to derive rest of the clocks or should I use 16 MHz clock for clock division.
Since deriving 1/3 and 1/21 from 250 Hz clocks require counters or registers of smaller size, Im inclined to do the same.
Kindly Help..
Thank You in advance.
Kindly Help..
