aaron_do
Member level 3
Hi all,
I want to use a multilayer LC filter in my design, but I'm worried about how to hook up the ground. These are the filters I'm referring to.
My issue is that the ground pins are on the sides, whereas I'm using microstrip lines in my board. I can move the side ground planes closer to hook up this filter, but the question is, what is the return path for the current? Unfortunately, I don't have the resources to simulate this.
The second question is, do I join the two side ground planes together underneath the chip? I assume it would improve the input-output isolation, but I'm worried it would again mess with the return path. Any thoughts, or links would be helpful.
thanks,
Aaron
thanks,
Aaron
