multi tone modulation using FM techniques
abhijitrc
Full Member level 1
Bangalore, India, India
How to find modulation index for a multi tone FM signal ? Let us take our real case:
we have 8 KHz sub carrier ( use to modulate PSK data), apart from that we have 27.777KHz and 8Hz as tone signals , Is it possible to modulate all these tones using a single carrier? How the spectrum will look ? what will be the modulation index ?? plz guide me.
Multi carrier modulation is very common on FM band 2 transmitters. All stereo transmissions modulate directly on the carrier left plus right signals, then there is a fixed subcarrier at 19 KHZ and the stereo difference signal is modulated on to a 38 KHZ carrier which is modulated on to the FM carrier. There are in addition, SCA channels that carry traffic data. So loads of carriers on a FM carrier.
Frank
In FM modulation, the modulation index is not important in itself but the bandwidth of the broadcasted FM signal is.
As you know, the FM modulation index for a sinusoidal modulating signal is defined as:
β = ΔFc/Fm
where:
ΔFc is the carrier deviation
Fm is the modulating frequency.
For EACH sinusoidal modulating signal of freqency Fm, the bandwith of the FM signal could be given as:
BW = 2 * ( ΔFc + Fm ) = 2 * ( β*Fm + Fm )
BW = 2 * Fm * ( β + 1 )
For multi tone FM broadcasting, the FM bandwidth should not exceed usually a limit (as 200 KHz for the radio FM Band, if I remember well).
Therefore for a constant BW, increasing Fm imposes on β to be lowered.
A generic N+tone modulated FM signal can be represented as:
y(t)=cos{ωc•t+K•[A1/ω1*sin(ω1•t)+A2/ω2*sin(ω2•t)+...+AN/ωN*sin(ωN•t)}
where K is the constant in Hz/V to convert from amplitude to frequency and Ai is the amplitude of the i-th tone.
each tone will have its own modulation index. they will be:
index1=K•A1/ω1
index2=K•A2/ω2
indexN=K•AN/ωN
(of course wi=2•Π•fi)
To estimate the occupated bandwidth you can use the Carson's rule:
first of all we need to calculate the maximum deviation frequency Δfmax=K•max(Ai)
then we will need the deviation rate: DR=Δfmax/max(fi)
BW≈2•Δfmax•(1+1/DR)
Finally the spectrum will be expressed in terms of products of Jn bessel functions.
Yes
How the spectrum will look?
There will be ( β + 1 ) significant sideband pairs for each sinusoidal modulating signal
Please note that the range of β in FM is:
0 ≦ β < infinity
The AM index for non-distorted envelope:
0 ≦ β ≦ 1
what will be the modulation index?
As you noticed, there is not a single modulation index for multi tone FM signal as in AM.
