Multi-source error during synthesis
soloktanjung
Full Member level 6
nowhere
xst 528 multi-source in unit
Hi friends,
I've got this error while doing synthesis and stuck for about a week. If anybody has any idea, please point me out what correction should I made in the code.
I'm using Xilinx ISE 9.2i.
`timescale 1ns / 1ps
module stage4(clk,
				  rst,
				  s3a,
				  s3b,
				  s3c,
				  s3d,
				  s3e,
				  s3f,
				  s3g,
				  s3h,
				  data_out0,
				  data_out1,
				  data_out2,
				  data_out3,
				  data_out4,
				  data_out5,
				  data_out6,
				  data_out7);
	input			clk, rst;
	input		signed	[15:0]	s3a, s3b, s3c, s3d, s3e, s3f, s3g, s3h;
	output	signed	[16:0]	data_out0, data_out1, data_out2, data_out3;
	output	signed	[16:0]	data_out4, data_out5, data_out6, data_out7;
//	10 add/sub, 8 shift
	reg	[2:0]	count8_adder_stage4;
	wire	[2:0]	select1_stage4;
	wire	[1:0]	select2_stage4;
	wire			add1, add2;
	always@(posedge clk, posedge rst)
	begin
		if(rst)
			count8_adder_stage4<=0;
		else if(count8_adder_stage4==5)
		else
			count8_adder_stage4<=count8_adder_stage4+1;
	end
	assign select1_stage4 = count8_adder_stage4;
	assign select2_stage4 = count8_adder_stage4[1:0];
	assign add1 = (select1_stage4==0) || (select1_stage4==5);
	assign add2 = (select1_stage4==2);
//	2 mux for input to the adder.
//	(* signal_encoding = "user" *)
	reg	signed	[16:0]	data_out0, data_out1, data_out2, data_out3;
	reg	signed	[16:0]	data_out4, data_out5, data_out6, data_out7;
	reg	signed	[15:0]	mux1_stage4, mux2_stage4, mux3_stage4, mux4_stage4;
	reg	signed	[15:0]	s3d_3, data_out6_3;
	wire	signed	[15:0]	data_out0_1, s3d_1, s3d_2, s3b;
	wire	signed	[15:0]	data_out6_1, data_out6_2;
	assign	data_out6_1 = data_out2>>>1;
	assign	data_out6_2 = data_out2>>>3;
	assign	s3d_1 = s3d>>>1;
	assign	s3d_2 = s3d>>>3;
	assign	data_out0_1 = data_out0>>>1;
	always@(select1_stage4, s3a, data_out0_1, s3d_3, s3d_1, data_out6_3, data_out6_1)
	begin
			case(select1_stage4)
			3'd0:	mux1_stage4=s3a;
			3'd1: mux1_stage4=s3d_1;
			3'd2: mux1_stage4=data_out0_1;
			3'd3: mux1_stage4=s3d_3;
			3'd4: mux1_stage4=data_out6_1;
			3'd5: mux1_stage4=data_out6_3;
			default:mux1_stage4=0;
			endcase
	end
	always@(select1_stage4, s3b, s3d_2, s3c, data_out6_2, s3d)
	begin
			3'd0:	mux2_stage4=s3b;
			3'd1: mux2_stage4=s3d_2;
			3'd2: mux2_stage4=s3b;
			3'd3: mux2_stage4=s3c;
			3'd4: mux2_stage4=data_out6_2;
			3'd5: mux2_stage4=s3d;
			default:mux2_stage4=0;
			endcase
	end
	wire		signed	[16:0]	add1_stage4;
	assign add1_stage4 = add1?(mux1_stage4 + mux2_stage4):(mux1_stage4 - mux2_stage4);
	begin
		if(rst)
			begin
			data_out0<=0;
			data_out4<=0;
			data_out6<=0;
			data_out2<=0;
			s3d_3<=0;
			data_out6_3<=0;
			end
		else
		begin
			3'd0: data_out0<=add1_stage4;
			3'd1: s3d_3<=add1_stage4;
			3'd2: data_out4<=add1_stage4;
			3'd3: data_out6<=add1_stage4;
			3'd4: data_out6_3<=add1_stage4;
			3'd5: data_out2<=add1_stage4;
			default:{data_out0, data_out4, s3d_3, data_out6, data_out6_3, data_out2}<=0;
			endcase
		end
	end
	wire	signed	[15:0]	s3h_1, s3g_1;
	reg	signed	[15:0]	s3g_3;
	wire	signed	[15:0]	data_out5_1;
	assign	s3h_1 = s3h>>>3;
	assign	s3g_1 = s3g>>>3;
	assign	data_out5_1 = data_out5>>>1;
	always@(select2_stage4, s3e, s3g, s3f)
	begin
			case(select2_stage4)
			3'd0:	mux3_stage4=s3e;
			3'd1: mux3_stage4=s3g;
			3'd2: mux3_stage4=s3f;
			3'd3: mux3_stage4=s3g;
			default:mux3_stage4=0;
			endcase
	end
	always@(select2_stage4, s3h_1, s3g_1, s3g_3, data_out5_1)
	begin
			3'd0: mux4_stage4=s3h_1;
			3'd1: mux4_stage4=s3g_1;
			3'd2: mux4_stage4=s3g_3;
			3'd3: mux4_stage4=data_out5_1;
			endcase
	end
	wire	signed	[16:0]	add2_stage4;
	assign add2_stage4 = add2?(mux3_stage4 + mux4_stage4):(mux3_stage4 - mux4_stage4);
	begin
		if(rst)
			begin
			s3g_3<=0;
			data_out3<=0;
			data_out5<=0;
			data_out7<=0;
			end
		else
		begin
			3'd0: data_out7<=add2_stage4;
			3'd1: s3g_3<=add2_stage4;
			3'd2: data_out5<=add2_stage4;
			3'd3: data_out3<=add2_stage4;
			default:{data_out7, s3g_3, data_out5, data_out3}<=0;
			endcase
		end
	end
	begin
		if(rst)
			data_out1<=0;
		else
			data_out1<=s3h;
	end
endmodule
The errors say:
ERROR:Xst:528 - Multi-source in Unit <stage4> on signal <mux2_stage4<15>>
Sources are:
   Signal <_n0000<15>> is assigned to logic
   Signal <mux2_stage4<15>> in Unit <stage4> is assigned to GND
ERROR:Xst:528 - Multi-source in Unit <stage4> on signal <mux2_stage4<14>>
Sources are:
   Signal <_n0000<14>> is assigned to logic
   Signal <mux2_stage4<14>> in Unit <stage4> is assigned to GND
ERROR:Xst:528 - Multi-source in Unit <stage4> on signal <mux2_stage4<13>>
Sources are:
   Signal <_n0000<13>> is assigned to logic
   Signal <mux2_stage4<13>> in Unit <stage4> is assigned to GND
ERROR:Xst:528 - Multi-source in Unit <stage4> on signal <mux2_stage4<12>>
Sources are:
   Signal <_n0000<12>> is assigned to logic
   Signal <mux2_stage4<12>> in Unit <stage4> is assigned to GND
ERROR:Xst:528 - Multi-source in Unit <stage4> on signal <mux2_stage4<11>>
Sources are:
   Signal <_n0000<11>> is assigned to logic
   Signal <mux2_stage4<11>> in Unit <stage4> is assigned to GND
ERROR:Xst:528 - Multi-source in Unit <stage4> on signal <mux2_stage4<10>>
Sources are:
   Signal <_n0000<10>> is assigned to logic
   Signal <mux2_stage4<10>> in Unit <stage4> is assigned to GND
ERROR:Xst:528 - Multi-source in Unit <stage4> on signal <mux2_stage4<9>>
Sources are:
   Signal <_n0000<9>> is assigned to logic
   Signal <mux2_stage4<9>> in Unit <stage4> is assigned to GND
ERROR:Xst:528 - Multi-source in Unit <stage4> on signal <mux2_stage4<8>>
Sources are:
   Signal <_n0000<8>> is assigned to logic
   Signal <mux2_stage4<8>> in Unit <stage4> is assigned to GND
ERROR:Xst:528 - Multi-source in Unit <stage4> on signal <mux2_stage4<7>>
Sources are:
   Signal <_n0000<7>> is assigned to logic
   Signal <mux2_stage4<7>> in Unit <stage4> is assigned to GND
ERROR:Xst:528 - Multi-source in Unit <stage4> on signal <mux2_stage4<6>>
Sources are:
   Signal <_n0000<6>> is assigned to logic
   Signal <mux2_stage4<6>> in Unit <stage4> is assigned to GND
ERROR:Xst:528 - Multi-source in Unit <stage4> on signal <mux2_stage4<5>>
Sources are:
   Signal <_n0000<5>> is assigned to logic
   Signal <mux2_stage4<5>> in Unit <stage4> is assigned to GND
ERROR:Xst:528 - Multi-source in Unit <stage4> on signal <mux2_stage4<4>>
Sources are:
   Signal <_n0000<4>> is assigned to logic
   Signal <mux2_stage4<4>> in Unit <stage4> is assigned to GND
ERROR:Xst:528 - Multi-source in Unit <stage4> on signal <mux2_stage4<3>>
Sources are:
   Signal <_n0000<3>> is assigned to logic
   Signal <mux2_stage4<3>> in Unit <stage4> is assigned to GND
ERROR:Xst:528 - Multi-source in Unit <stage4> on signal <mux2_stage4<2>>
Sources are:
   Signal <_n0000<2>> is assigned to logic
   Signal <mux2_stage4<2>> in Unit <stage4> is assigned to GND
ERROR:Xst:528 - Multi-source in Unit <stage4> on signal <mux2_stage4<1>>
Sources are:
   Signal <_n0000<1>> is assigned to logic
   Signal <mux2_stage4<1>> in Unit <stage4> is assigned to GND
ERROR:Xst:528 - Multi-source in Unit <stage4> on signal <mux2_stage4<0>>
Sources are:
   Signal <_n0000<0>> is assigned to logic
   Signal <mux2_stage4<0>> in Unit <stage4> is assigned to GND
Thanks in advance.
Hairo
xst:528
      default:mux2_stage4=0;    <=======
this is your 'multisource' problem;
mistyped mux2_stage4 instead of:mux4_stage4 ?
if not you have to rewrite the code to drive mux2_stage4 to one level
with every combination of select1_xx and select2_xx signals;
xst:528 - multi-source in unit on signal
Thank you very much j_andr.
The problem solve. As I work with the code for many hours, I did'nt notice that simple mistyped.
Thanks you for your attention.
