Thanks, I'l take a look at thatnamqn said:Have a look at this page (programming software and schematic for hardware):
h**p://perso.wanadoo.fr/softelec/Projects/PIC18/Projects_PIC18_us.htm
Cheers,
predrage said:You can use JDM programmer + winpic800 software. This combination works fine for me.
Bootloader for PIC18F4550 is the simplest for U, search with google . . . . many and many . . . . .aghielan said:i need simple programmer circuit for PIC18F4550. it seems costly for me to buy the programmer. So i need selfmade kit.
Thanks & Regards.
Programming...
Erasing ("bulk" or "chip") ...
Programming CODE, 0x000000..0x007FFE
Verifying CODE, 0x000000..0x007FFE
Verifying 0x000000..0x007FFE
Verify Error: 000000: read 000000, wanted 00EF15, mask 00FFFF ==> diff=00EF15
Verify Error: 000002: read 000000, wanted 00F000, mask 00FFFF ==> diff=00F000
Verify Error: 000004: read 000000, wanted 00FFFF, mask 00FFFF ==> diff=00FFFF
Verify Error: 000006: read 000000, wanted 00FFFF, mask 00FFFF ==> diff=00FFFF
More Verify Errors, unable to list all (total=8107)
Programming DATA, 0xF00000..0xF000FF
Verifying DATA, 0xF00000..0xF000FF
Verifying 0xF00000..0xF000FF
Verify Error: F00000: read 000000, wanted 0000FF, mask 0000FF ==> diff=0000FF
Verify Error: F00001: read 000000, wanted 0000FF, mask 0000FF ==> diff=0000FF
Verify Error: F00002: read 000000, wanted 0000FF, mask 0000FF ==> diff=0000FF
Verify Error: F00003: read 000000, wanted 0000FF, mask 0000FF ==> diff=0000FF
More Verify Errors, unable to list all (total=62)
Programming CONFIG, 0x300000..0x30000C
Verifying CONFIG, 0x300000..0x30000C
Verifying 0x300000..0x30000C
Verify Error: 300000: read 000000, wanted 000F24, mask 00FFFF ==> diff=000F24
Verify Error: 300002: read 000000, wanted 000039, mask 00FFFF ==> diff=000039
Verify Error: 300004: read 000000, wanted 008100, mask 00FFFF ==> diff=008100
Verify Error: 300006: read 000000, wanted 000080, mask 00FFFF ==> diff=000080
More Verify Errors, unable to list all (total=7)
ERROR: Programming FAILED !
I don't have a 628a, it did work on the 877A though if that helps any...vsmGuy said:JDMs are not very reliable. Try programming a stock 628a first.
