.mt# files blank in HSPICE simulation output
gurunath.kadam
Newbie level 6
Darmstadt, Germany
While running HSPICE simulations with following options:
.OPTION AUTOSTOP
.OPTION POST=2
.OPTION MEASFORM=3
.OPTION PROBE
I am getting .mt# files as blank. The output is not 'failed', but the files are completely blank with 0 bytes size.
The weird thing is with same options and measure statements I got proper output for one of simulation run, all others are failing. In each case the .tr# files are properly generated with appropriate resulting waveform.
I checked .lis, .warnlog and other corresponding files but I found no clue why this is happening.
Any help will be appreciated.
Thank you.
update:
I ran earlier simulations with
-dp # -mt # -hpp
switches, when the .mt# files produced were empty.
I ran same simulations with only
-dp #
option and now my .mt# files are properly written. But this has increased my simulation time by almost 33%!
Same simulations with
-dp # -mt #
switches gave blank .mt# files. But after checking the .lis file I saw that 'hpp' was used by the simulator by itself.
Also, with multi-processing, multi-threading and parallel precision options I tried changing the .mt# files format to HSPICE default but still files were blank.
Increasing the warnlimit to 100 has not produced any warnings about .mt# files.
I will try something more meanwhile.
Thank you.
