AnuHV
Member level 2
Hi ,
I have executed the following ADC program for single channel by connecting my flex sensor .When i checked the register ADC12MEM0 for digital output i could not find any changes.Please someone tell me where i have gone wrong? should i enable any interrupt in particular for this program?
MSP-FET430P440 Demo - ADC12, Single Conversion on Single Channel
// This example shows how to perform a single ADC12 conversion on a single
// channel. It uses AVcc for the reference and performs a single conversion on
// channel A0. The conversion results are stored in ADC12MEM0. Test by applying
// a voltage to channel A0, then setting and running to a break point at the
// "_NOP()" instruction. To view the conversion results, open a register window
// with the debugger and view the contents of ADC12MEM0.
// ACLK = n/a, MCLK = SMCLK = default DCO, ADC12CLK = ADC12OSC
// MSP430F449
// Vin -->|P6.0/A0 |
// M. Mitchell
// Texas Instruments Inc.
// Feb 2005
// Built with IAR Embedded Workbench Version: 3.21A
#include <msp430x44x.h>
void main(void)
WDTCTL = WDTPW+WDTHOLD; // Stop watchdog timer
P6SEL |= 0x01; // Enable A/D channel A0
ADC12CTL0 = ADC12ON+SHT0_2; // Turn on ADC12, set sampling time
ADC12CTL1 = SHP; // Use sampling timer
ADC12CTL0 |= ENC; // Enable conversions
while (1)
ADC12CTL0 |= ADC12SC; // Start conversion
while ((ADC12IFG & BIT0)==0);
_NOP(); // SET BREAKPOINT HERE
