eDance
Junior Member level 3
isp1581 interrupt why
Hi all, I can't get ISP1581's interrupt output signal, plz help me!
I think I have configed all neccessary registers for interrupt signal output pin, such as GLINTEN bit of mode register,also the interrupt configure register & interrupt enable register, and I tried every trigger mode, but saddly the output is always high(high level trigger mode) or low(low level trigger mode), no pulse appears even when the BRESET and HS-STAT bits are set.
I'm waiting for your help, thank you so much!
