I used the precompiled version that comes with a neat installer for windows. But to make the sourcecode I had to write the compiler commands into a seperate batch file because the make tool didn't work for me. And now I can only load the created dbg file into the debugger program but to download the file into the target I have to communicate through the proxy program that is included. However this proxy program that should be the interface between tcp and jtag does not find the target hardware although you can not misconfigure the settings. It should be plug'n play but it doesn't work.I tried several windows operating systems on different machines but neither did work.
During the next months it is my trainee task to setup the controller so that it can be used for microcontroller experiments. Thats the reason why I planned to use this freeware so that it is possible to try the hardware at home without any licencing problems.
