MPX4115 Pressure sensor based on PIC16F877a
Ali A. Noori
Newbie level 3
Newbie level 3
Hi
I found this Website very interesting and I have some equations in my attached project
I designed my project based on PIC 16F877A by using Proteus 7.6 and Proton IDE basic
the result of pressure in LCD is incorrect
Basic Code In PROTON PROGRAM
Device = 16F877A
XTAL 4
Cls
ALL_DIGITAL true
' LCD connections
LCD_DTPIN PORTB.0
LCD_RSPIN PORTC.1
LCD_ENPIN PORTC.0
LCD_INTERFACE 8
' Define A/D converter parameters
Declare ADIN_RES 8 ' 8-bit result required
Declare ADIN_TAD FRC ' RC OSC chosen
Declare ADIN_STIME 50 ' Allow 50us sample time
' Variables
Dim R As Float untitled.JPG' A/D converter result
Dim P1 As Float ' pressure in mmhg
Dim P2 As Float
Input PORTA.0 'TRISA = 1 ' RA0 (AN0) is input
Output PORTB 'TRISB = 0 ' PORTB is output
DelayMS 500 ' Wait 0.5sec for LCD to initialize
' Initialize the A/D converter
ADCON1 = 0 ' Make AN0 to AN4 as analog inputs, Analogue to Digital Converter control register,
'that chooses which pin is analogue and which is digital.
' make reference voltage = VDD
ADCON0 = %11000001 ' A/D clock is internal RC, select AN0 ,Analogue to Digital Converter control register.
' Turn on A/D converter
Cls ' Clear LCD
loop:
' Start A/D conversion
ADCIN 0, R ' Read Channel 0 data
P1= (0.1087*R + 9.0175)
P2= P1 *760/101.325 ' convert 760mmhg=101.325 kPa
Print At 1,1,"Pressure= ",DEC2 P2, "KPa" ' Display decimal part
DelayMS 250 ' Wait 1 second
GoTo loop ' Repeat
End
See if you have to configure CMCON register in code. You have to disable Comparator register on PORTA to use ADC. If that doesn't work then your conversion formula is wrong. Provide the website where the project is mentioned.
See attached project.
  • mpx4115.rar
I don't know the language you are using but give me the formula for different conversion I can help you in another programming language c,Mikroc or assembly.
