dy12
Newbie level 1
I know that MPPT is used to boost the voltage from solar panel. i need to know if i have to make sure that the current output of solar panel be less than the output current of the MPPT. will the current from the solar panel ever increase to its maximum level? is the output current of solar panel has to be less than the output current of MPPT..or they have to be the same?
Thank you in advance for your help
