[SOLVED] MPLABX compiler error, i need help
thunderboympm
Full Member level 5
Full Member level 5
Malappuram, India
friends i got error from mplabx v1.03 when i compiling i got this error
java.io.FileNotFoundException: D:\Projects\febin\new test.X\build\default\production\_ext\678254406\LEVEL\.d (The system cannot find the path specified)
        at java.io.FileOutputStream.open(Native Method)
        at java.io.FileOutputStream.<init>(Unknown Source)
        at java.io.FileWriter.<init>(Unknown Source)
        at com.microchip.mplab.extractobjectdependencies.ExtractObjectDependencies.main(ExtractObjectDependencies.java:103)
i got the solution because of the name space error. mplabx does not support the spaces between the folder or project files
