mp3 core/LAN core for xilinx virtex
smoothjoey
Newbie level 6
Newbie level 6
Does anyone have a mp3 decoder or a LAN core for a xilinx virtex fpga. I would like to build a device that plugs into the network and I can stream mp3s top it. The dvice would decode it then output it to my receiver.
I have a viterx fpga and I need an mp3 and LAN core for it. Does anyone have these?
I need Lan core to and a good cpu core to run enbeded linux on spartan IIE
Getting MP3 decoding going on a Xilinx may be quite difficult. Have you thought of using a dedicated decoder chip such as the MAS35xx series? (https://www.micronas.com)
You will also need to have some sort of CPU to string this all together again the opencores site have a few!
An alternative could be to use the LEON sparc core (https://www.gaisler.com) configured with the single cycle Multiply/accumulate and see if an open source MP3 decoder could be ported to it... Ahem! quite a lot of work :smile:
OK, so now I see another post on the Hardware forum talking about a kit for an MP3 Decoder with a Hard Drive.
( ?topic=12939&forum=31 )
https://www.pjrc.com/
This might be a better starting place..
So much information, so little time.
Cheers,
++Sys
May be you can use the VoIP dev kit from X. That comes already with a UDP stack and some DAC.
Prob. its easier to use an external decoder chip!!!
int64
LaTeX Commands Quick-Menu:
