moving objects by Parametric in HFSS
Hi Topor89,
Geometry animation can be done by following steps.
1) Right click in 3D Modeler window. select View-->Animate
2) Select the Parameter to Optimize
3) Choose desired start,stop,step values for swept variable
4) Result would be like this... View attachment Geometry animation.zip
Hope this helps.
Yes, it helped!
Before I sow the post I have found the answer by myself.
But still Your answer is EXACTLY what I was looking for.
Thank You very much!
Is it possible in HFSS to animate a 3d plot showing fields where two structural variables are changing at the same time?
