[Moved] Which tool to use for connecting wire
jaycec
Member level 2
india
Hi all
I dont know where exactly to put this thread so please forgive me if i put it on the wrong place.
i bought connectors like shown in the image and crimp for them.I thought of using ordinary pliers to connect wire to crimp but i later found that connecting crimp and wire using pliers will result in poor joint ,which will be difficult to push into connectors female part.So please suggest me the best tool to do the task perfectly.
thanks in advance.
Molex connector pins; they can be attached with small pliers but as you have found they can easily slide off as its difficult to properly crimp the wire in place.
I attach them with pliers but then run a bit of solder around the wire / crimp area being careful not to leave too much solder on the connector otherwise it does not fit into the housing.
There are proper crimping tools but generally too expensive for the hobbyist.
Reactions: bigdogguru
    bigdogguru
    V
The technique wp100 describes is a good one.
I would also have to agree with wp100 that the "Molex" brand crimpers are horrifically expensive, generally in the $200 to $500 range, not to mention the number of variations of the crimp/connector style.
There are some less expensive alternatives, IDEAL offers a crimping tool for less than $50 and various dies for around $30.
They offer what they describe as a "ring tongue terminal" die, probably to avoid a lawsuit, which will work with the terminal/connector you have pictured.
Although, I would still apply some solder as wp100 suggested.
BigDog
    V
