Oct 22, 2011 #1 P phatcreators Full Member level 5 Joined Sep 2, 2011 Messages 315 Helped 24 Reputation 48 Reaction score 24 Trophy points 1,298 Activity points 3,458 What's this components is TIP 142F ? How to test it ? thanks
Oct 22, 2011 #2 C Chris1990 Junior Member level 1 Joined Oct 19, 2011 Messages 17 Helped 3 Reputation 6 Reaction score 2 Trophy points 1,283 Activity points 1,383 Re: What's this components is TIP 142F ? http://www.datasheetcatalog.org/datasheet/PowerInnovations/mXtyyzx.pdf that component?
Oct 22, 2011 #3 tpetar Advanced Member level 7 Joined Sep 27, 2010 Messages 6,417 Helped 1,713 Reputation 3,456 Reaction score 1,673 Trophy points 1,393 Location Pancevo-Belgrade, Serbia Activity points 37,363 Re: What's this components is TIP 142F ? TIP142F is NPN Darlington Transistor Datasheet You can find here : http://www.datasheetcatalog.org/datasheet/stmicroelectronics/4132.pdf
Oct 24, 2011 #4 P phatcreators Full Member level 5 Joined Sep 2, 2011 Messages 315 Helped 24 Reputation 48 Reaction score 24 Trophy points 1,298 Activity points 3,458 Re: What's this components is TIP 142F ? tpetar said: TIP142F is NPN Darlington Transistor Datasheet You can find here : http://www.datasheetcatalog.org/datasheet/stmicroelectronics/4132.pdf Click to expand... How to test it then in a circuit ?
Oct 24, 2011 #5 C Chris1990 Junior Member level 1 Joined Oct 19, 2011 Messages 17 Helped 3 Reputation 6 Reaction score 2 Trophy points 1,283 Activity points 1,383 Re: What's this components is TIP 142F ? by hooking it up? in a breadboard, base resistor, loose wire, led and resistor from vcc to collector, emitter to ground. connect wire to vcc and bish bash bosh, if led works, device works
