I have to create a test bench for oyr project which contains AXI4 BUS.
It's the forst time I'm dealing with BUS. Where can I find good tutorial of BUS structure and functionality, and after for AXI4.
I have to understant it well for implementing a driver (UVM) fot the axi bus (master).
Yeah, but you have to pay for those and a penny pinching company won't fork over the cash to pay for it, so I had to find one (ended up rolling my own).
If you find AXI4 overwhelming for the first time, start with AHB-Lite spec, then go for AXI4-Lite and finally AXI4 itself.
If you are going to write a BFM on your own well then good enough. Getting a free BFM (to understand how they are coded and how they work) can be challenging.
Here was my thread a couple of years back when I was looking for an AXI4-Lite BFM. https://www.edaboard.com/threads/332192/
You can use the above as your starting study material (if the links inside the thread are still working).
If I remember correctly, the SysWip BFM was working perfectly with the Xilinx AXI4 Interconnect IP.
These are very useful because they can hang off your buses in your testbench to check your BFM and/or your DUT at the same time. They can also be used in Formal verification, where you dont even need a BFM (but you do need a hideously expensive tool)
I have searched for UVM AXI4 BFM in github, but didn't find.
If you remember the name of the project it will elp me.
I have already read the AXI4 specifications from arm, but I wanted to read or see some tutorial which may help with some unclear issues.
I try to implement a transaction and driver, and not sure how to do it.
