amila133
Member level 4
These are my successful mikroC program codes.
Pls find the attachments.
FOR Master
For Slave
FOR Master
unsigned char count=0;
unsigned short receive;
void send_data();
void main(){
TRISD=0x00;
//TRISB=0xff;
PORTD=0x00;
ADCON1=0x06;
TRISA=0xff;
Spi_Init_Advanced(MASTER_OSC_DIV4,DATA_SAMPLE_MIDDLE, CLK_IDLE_LOW, LOW_2_HIGH);
/*while(1){
if(PORTB.f0){
count=count+1;
Delay_ms(250);
if(count==10){
PORTD=count;
send_data();
while(1){
if(PORTA.f0){
count=count+1;
PORTD.f0=1;
Delay_ms(750);
PORTD.f0=0;
if(count==10){
PORTD=count;
Delay_ms(750);
send_data();
PORTD=0x00;
do{
}while(PORTA.f0);
void send_data(){
TRISC = 0x10;
ADCON1=0x06;
TRISA=0x00;
TRISE=0x00;
PORTE.F2=1;
Delay_ms(200);
PORTE.F2=0;
Delay_ms(100);
Spi_Write(count);
while(SSPSTAT.F0==1){
receive=SSPBUF;
// PORTE.F2=1;
Delay_ms(200);
count=0;
For Slave
void receive_data();
void send_sms();
unsigned short receive,buffer;
int i;
const int count[3]={0x31,0x30};
void main(){
ADCON1=0x06;
TRISD=0x00;
TRISA=0xff;
TRISB=0x00;
PORTC=0x00;
PORTD=0x00;
PORTB=0x00;
Spi_Init_Advanced(SLAVE_SS_ENABLE, DATA_SAMPLE_MIDDLE, CLK_IDLE_LOW, LOW_2_HIGH);
while(1){
PORTB.F0=1;
Delay_ms(500);
PORTB.F0=0;
receive_data();
send_sms();
void receive_data(){
TRISC=0x18;
Delay_ms(50);
Delay_ms(50);
// TRISC=0x98;
receive=Spi_Read(buffer);
PORTD=receive;
Delay_ms(1000);
PORTD=0x00;
void send_sms(){
const unsigned char para[5]="AT\r\n";
const unsigned char textmode[12]="AT+CMGF=1\r\n"; //select pdu mode (o is given ; 1 is given for text mode)
const unsigned char smsc[23] ="AT+CSCA=\"+947100003\"\r\n" ; //message center no
const unsigned char recepient[24]="AT+CMGS=\"+94712870330\"\r";
const unsigned char message[3]="12";
//const unsigned char message1[3] =count;
// const unsigned char dial[17] ="ATD0712870330;\r\n";
Usart_Init(9600);
TRISB=0;
PORTB=0;
/* for( i=0;i<10;i++){
count++;
for(i=0;i<5; i++){
Usart_Write(para[i]); //type at
//Delay_ms(200);
//Usart_Write(0x0D); //enter
//Usart_Write(0x0A); //new line
PORTB=1;
Delay_ms(3000);
PORTB=0; //set textmode
for(i=0;i<12;i++) {
Usart_Write(textmode[i]);
//Delay_ms(200);
PORTB=1;
Delay_ms(4000);
PORTB=0;
for(i=0;i<23; i++){ //SERVICE CENTER NO
Usart_Write(smsc[i]);
//Delay_ms(200);
PORTB=1;
Delay_ms(4000);
PORTB=0;
for(i=0;i<24;i++) {
//if(command1[i]=='\0') break;
Usart_Write(recepient[i]); //recepinet no
//Delay_ms(50);
// Usart_Write(0x0D); //enter
Delay_ms(400);
// Usart_Write(count);
//Usart_Write(0x31);//1
for(i=0;i<3;i++){ //send message
// if(command1[i]=='\0') break;
Usart_Write(count[i]);
Delay_ms(50);
//Usart_Write(count);
Usart_Write(0x1A); //ctrl+z
PORTB=1;
Delay_ms(4000);
PORTB=0;
//for(i=0;i<17;i++){ //dial really starting
// if(dial[i]=='\0') break;
// Usart_Write(dial[i]);
// // Delay_ms(200);
PORTB=1;
Delay_ms(1000);
PORTB=0;
