[Moved] Reading from another MCU and writing and copying information C++
sheffladreece
Newbie level 3
Newbie level 3
C++
What I would like to do is make two MCUs (atmega328p) connected via Rx and Tx terminals read each others internal memory and copy the data to its own.
Example:
On MCU 1- Indentity = 123
On MCU 2- Indentity = 456
What I am aiming to achieve is for MCU 1 to read MCU 2s indentity of (456) and copy the code into its own memory. Having the ability to recall that MCU 2s identity = 456 even when the two are not connected.
How would this be coded using C++??
MCU1 sends Identity data to MCU2. MCU2 reads it and saves it in its internal eeprom. MCU restarts and reads eeprom and loads the MCU1's Identity data to a variable and this will be available when MCU2 is running. After MCU2 reads and saves MCU1's data then MCU2 can send its data to MCU1.
LaTeX Commands Quick-Menu:
