[Moved]Problem sending GET to webserver from SIM900 with AT commands
nimaaa
Newbie level 6
Newbie level 6
Tehran, Iran, Iran
Sending a Single data to Web Server via Sim900's Get Method
HI All
I want to send a single data to my webserver , and I want to use get Method
but after using AT+HTTPACTION sim900 gives me the 404 error
do you know how I should solve that ??
my At Commands are :
AT+SAPBR=1,1
AT+HTTPINIT
AT+HTTPPARA="CID",1
AT+HTTPPARA="URL","http:///mydomain.in/nri.php?data=10"
AT+HTTPACTION=0
AT+HTTPTERM
and my php code in nri.php is :
<?php
echo " Nima" ;
$var1=$_GET['data'] ;
echo $var1 ;
Thanks in Advance
Referring To Old Thread :
https://www.edaboard.com/threads/281314/
Re: Sending a Single data to Web Server via Sim900's Get Method
why three / in ?
Reactions: nimaaa
    nimaaa
Hi horace
thank you . but when I was trying my code in hyperterminal , I entered it correctly with two "//". I'm sure about this part
and '.in' is part of my domain address like .com
any way thank you for reminding my mistake . I'm going to edit it right now
AT+HTTPPARA="URL","http://mydomain/nri.php?data=10"
any idea ?
@nimaaa, has the problem been solved?
Hi ogbeni
yes . now I don't get the 404 error and I connected to my host successfully.
my mistake was that I was entering my AT Command with uppercase letters while my nri.php is saved with lowercase letters in my host
AT+HTTPPARA="URL","HTTP://MYDOMAIN/nri.php?data=10" is OK
but still I cant' see any data in my PHP page
I just need a simple PHP code to get this data and show it in my page without any options
what is problem with my php code ??
<?php
echo " nimaaa" ;
echo $var1 ;
I tried your php code , too , but it didn't work
I reviewed your post. To be serious I don't know if you actually understand the difference between GET and POST.
Common sense helps, GET means to read data from a server. Respectively you'll perform first an AT+HTTPACTION=0 command, then use AT+HTTPREAD to receive the data. There are pretty clear examples in the SIMCOM FTP HTTP AT Commands User Guide.
Hi FVM
Get is not just for receiving data . It can sends data too . but it's difference with post that it doesn't have enough security because in this Method data is included in the URL and it is visible for everyone
Both of them are methods for sending and recieving data . when data is sent with GET method , it should be received by GET method , too
as you see I have included my data in URL , in my second HTTPPARA at command
Apart from the question what can be generally done with HTTP GET and POST methods (I'm not motivated to argue in this regard), it's possibly reasonable to refer to the description in SIMCOM manual.
I don't think that SIMCOM is prepared to interact with php scripts.
you are right FVM . we are not here to argue :wink:
I'm sending data to my webserver via sim900's GET method ( as you said POST method is possible too) and surly in my webserver I'll need PHP code to receive the data
I'm just looking for this php code :(
