[moved] Power Supply Design with two USB outputs
nikhil.medhe
Hello,
I need to design a 150V - 230V AC input to 5V, 1.5A DC output power supply which has two USB Outputs.
Should I go for the transformerless design or should I include a transformer?
In any of the above cases, what should be the circuit diagram?
I would appreciate your help on this point. Thanks in advance!
- Nikhil
Go with the transformer. Step down the input voltage and do the conversion. Use a regulator which is able to provide 5V with 3A, As you said need two USB outputs. So 1.5A for both
Reactions: Dont
    Dont
Thank you for the answer! However I have one more query. What should be the specifications of the transformer I should be using?
The transformer could be a 230V/6V (10W). You also need a rectifier bridge, a filtering capacitor and a linear series regulator (LM338 - 5A).
I think 230V/6V will be marginal case so better go with 230V/9V or 230V/12V. That should be fine
Reactions: Dont
    Dont
Too much power losses in the linear regulator (for 3A current) with 9V/12V AC.
For 6V AC you get ~ 8.4 DC (more than enough for a series regulator).
Do you recommend we use a 230v to 6v transformer in that case?
