[MOVED] power management IC-twl6030
svg
Member level 1
Member level 1
HI FRNDS,
what is the use of smart reflex in PMIC??? smart reflex means???? if any body knows plz reply for my ques.....thanks in advance!!!!:-x
Re: power management IC-twl6030
HI FRNDS,
Smart Reflex is the TI power monitoring system (V/I regulator).
in PMIC, the smart reflex is used to monitor the voltage , current parameters and rise an alarm if the device goes out of the required value. Generally, input power rails are monitored by this chip.
Thank you
