[Moved] PIC18f4550 board to board communication problem using USART
Harshal Dalal
Newbie level 3
Newbie level 3
hello everyone ,
I am interested in communication between to pic18f4550 hardware.
here is my 2 code..
1st is for transmit from 1st board to another,
unsigned char txbuf[]={0x02, 0x31, 0x37, 0x3B, 0x3B, 0x44, 0x45,0x03,};
unsigned char z, i;
void TXbyte(char data)
    while(TXSTAbits.TRMT==0); //wait tiiltransmit buffer in not empty
    TXREG = data; // Transmit Data
}//end TXbyte
void main()
SPCON1 = 0; // Make sure SPI is disabled //Refer Datasheet
 TRISCbits.TRISC7=1; // RX
 TRISCbits.TRISC6=0; // TX
 SPBRG = 0x9B; //4800 baud XTAL=20MHz, Fosc=48Mhz
 TXSTA = 0x20; // TX enable BRGH=0
 RCSTA = 0x90;
 for(i=0;txbuf[i]!='\0';i++)
   TXbyte(txbuf[i]);
}//main ends
and here is my 2nd code to receive the data from 1st board
void main()
SSPCON1 = 0; // Make sure SPI is disabled //Refer Datasheet
 RCSTA = 0x90; // continuous RX
 BAUDCON = 0x00; // BRG16 = 0
for(i=0;i<8;i++) //for loop receive 8 byte to receive and it will store in rxbuf
 while(PIR1bits.RCIF==0); //Wait util data from PC is received
 rxbuf[i]=RCREG;
 PIR1bits.RCIF = 0;
if (rxbuf[1]==0x31 && rxbuf[2]==0x37 ) // this loop will check 1st and 2nd byte whether it is 1 and 7 or not
PORTBbits.RB5=1;
my both code is perfectly working on hyper terminal and proteus simulation when i connect them "SEPARATELY" with PC
but when i try connect two pic with rs232 then its not working...
so plz help me.. yours suggestion are most welcome
please post here your schematic design with all connections that u have used.
if your code is working, it is very likely that your problem is hardware.:wink:
if I understand it right, it looks like you tried to use two COM ports on your PC?
The pc can not manage more than one COM.
Hi, I have done PIC to PC communication. Did you used MAX232 IC for the data transfer. Because there is a difference in the voltage levels of PC and PIC.
PC are usually RS232 whereas PIC are TTL logic levels. MAX 232 is used to convert these levels. Thanks.
Syed Fahad Wasti
thank you "Syed Fahad Wasti"
yes i have used MAX232 IC...and communication between PIC and PC is perfectly working....
I want to communicate one pic with another ....
I have connected my tx-pic and rx-pic with pc only one at a time...
but now i want to connect 2 pic tx to rx directly... now no PC in between
Well, in order to connect multiple PICs (One PIC must be a Master and other PIC must be a Slave), you can use either SPI protocol or I2C protocol ..
