[SOLVED] [moved] Monte carlo running as the ocean script problem
sarge
Full Member level 3
Hello,
In the one technology I'm trying to run MC simulation thru ocean script (because of IC 5 here :( ).
In GUI all running ok, so I've saved ocean script directly from this GUI and try to run this from icfb:
Such way gives for me:
*error* parseString argument #1 should be either a string or a symbol
One more time - GUI works well, and when I run the saved script from icfb it doesn't work.
The search provides info regardign lvs/drc error with such message, but not abou MC.
Do you have any thoughts how to fix that?
Thanks,
Sergey
erikl
Super Moderator
Staff member
Germany
Re: Monte carlo running as the ocean script problem
This is a very common error message from SKILL (resp. OCEAN): a function or procedure expecting a string or a symbol argument is missing that, meaning: instead received something different (or nil). E.g. a string, which isn't surrounded by its "string" tags.
sarge
Full Member level 3
Yes, you are right, but thing is that this is not my function or procedure - the error comes from somewhere inside of spectre. Sometimes, I believe, that I saw msg "loading monte.cxt", and right after that this error.
Usually, when I'm saving the script right from ADE window (in which simulation works) and then load this script to icfb without modification, I suspect that it should work proper without any problem, or I am wrong?
Regards,
Sergey
erikl
Super Moderator
Staff member
Germany
You're right, just go on and try it!
sarge
Full Member level 3
Ok, problem solved.
An issue was in that by default spectre has distribution run mode and that parameter doesn't move to script somewhy.
So, I've added:
hostMode('local)
And all works fine now.
Thanks for responses.
erikl
Super Moderator
Staff member
Germany
Ok, thank you, sarge,
... for your successful feedBack!
Marking your thread as "Solved"
