Apr 13, 2018 #1 U uri1636 Junior Member level 2 Joined Mar 22, 2013 Messages 22 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,446 I am not familiar with the HFSS software. I design a microstrip antenna with the CST. I transfer the CST model to HFSS model. When i do validation check i get that the: "Boundaries and Excitations " isn't ok. "Analysis Setup" insn't ok. How can i solve the problems?
Apr 14, 2018 #2 U uri1636 Junior Member level 2 Joined Mar 22, 2013 Messages 22 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,446 Re: microstrip antenna design at HFSS After a lot of work at HFSS design, when i do the "validation check" every thing is ok. Why i can't add Frequency Sweep?(The option is not enabled)
Apr 25, 2018 #3 U uri1636 Junior Member level 2 Joined Mar 22, 2013 Messages 22 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,446 When i comparing the results from the cst & hfss softwares i am getting different results, why?
Apr 26, 2018 #4 I ismail-patch Newbie level 2 Joined Apr 25, 2018 Messages 2 Helped 1 Reputation 2 Reaction score 1 Trophy points 3 Activity points 12 Hi, I advise you to see this PDF for know the different between HFSS and CST https://cdn.intechopen.com/pdfs/14726.pdf
