pkaras
Junior Member level 1
- Joined
- Aug 5, 2010
- Messages
- 16
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,415
Manufacturer recommends using the following LDO to power its module - LT1764AEQ. But this part is rather expensive. I am looking for a cheaper alternative. The main requirements are:
- Low dropout (5Vin, 4.2Vout)
- 1A max avg load, 2.5A bursts (hence fast response to load transients is required)
- Low output voltage ripple
- Little output voltage under/over shoots
- No soft start (full switch on in less than 1 ms)
- Protection against reverse current
- Reverse polarity protection would be an advantage
- SMD, low θJ-A
I have picked MIC39302 (θJ-A figure is not provided) and LP38501-ADJ (no reverse polarity protection). Can you please advice me if my choice is right?
- SMD, low θJ-A
