[Moved]Interface keypad and motor with p18f4520
mystickatara
Newbie level 3
Newbie level 3
Hi, I'm having problems with trying to get both my keypad and motor to work together. I am using a MPLAB IDE v8.92.
The theory for this code is when I click on '1' (case 1) on the keypad the motor will run for a short period of time. The codes are also the same for the other numbers '2', '3', and '4' as this is just a basic code I'm trying to get it working before adding more features into this. However it keeps on looping from case 0 to the while-loop and I don't know how to get it to stop looping and getting the keypad to work the way I want it to.
My whole code for keypad and motor is using PORTC. Motor is RC0 while the rest of the pins are using the keypad.
#include <p18f4520.h>
#include <delays.h>
#define KBD_DA  PORTCbits.RC6
#define KBD_OE  PORTCbits.RC5
#define KBD_DATA  PORTC
#define KBD_ENABLE_OUTPUT KBD_OE = 0;
#define KBD_DISABLE_OUTPUT KBD_OE = 0;
unsigned kbd_dec[4] =
  0x0,
  0x1,
  0x2,
  0x4,
void main()
		unsigned char kbd_data = 0, choice = 0, prev_kbd_data = 0;
		unsigned char matches = 0;
		int i = 0;
		PORTCbits.RC0=0; // Motor off initially.
		TRISC=0xff;
		KBD_ENABLE_OUTPUT;
  	while(1)
  		if(KBD_DA==1) //De-bouncing
  			choice = 0;
  			prev_kbd_data = (KBD_DATA & 0x1E);
  			matches =0;
  			while(matches < 3)
  				Delay1KTCYx(50);
  				if(prev_kbd_data == kbd_data)
  					matches++;
  				else
  					matches = 0;
  				prev_kbd_data = kbd_data;
  			switch(kbd_data)
				case 0:
					PORTCbits.RC0=0; //T 10 PULSE
					break;
				case 1:
					while(i<100)
						Delay100TCYx(90); //900?s delay
						PORTCbits.RC0=1; //T HIGH PULSE
						Delay100TCYx(10); //100?s delay
						i++;
					break;
				case 2:
					while(i<100)
							PORTCbits.RC0=0; //T 20 PULSE
							Delay10TCYx(100); //900?s delay
							Delay10KTCYx(20); //100?s delay
							i++;
					break;
				case 3:
					while(i<100)
							i++;
					break;
				case 4:
					while(i<100)
							i++;
					break;
if(KBD_DA==1)
Where PORTCbits.RC6 = PORTC & (1<<6)
So, the result can be 0x00 or 0x40 and never be 0x01
You better use simpler:
if(KBD_DA) ...
this is just a non-zero comparsion
Don't mind telling me where to add the first one? I'm still a novice in programming.
For read port state use PORTx register. For write LATx. But I recomend you to start from led blinking if you do not understand what we are talking about.
Don't use delays for the motor code. If a delay is executing then at that time the keypad will not respond. Use Timer interrupts.
