I would like to know how should I define the integration line for this kind of antenna ?
Is it ok to define the integration line as in the file "antenna with integration line.jpg" ( red line)? If not, then the arrow should be pointing in which way?
i think your using lumped port excitation, in that case, the interation line is taken from the top conductor to the bottom conductor ( in this case your feed line)
If I try to define like that, it tells me ¨Lines can only be created on select surfaces¨
It's like my integration line must be inside the excitation plane ( must be drawn inside that rectangle ).
Whenever I click outside of that rectangle it says ¨Lines can only be created on select surfaces¨
Does anyone know why and how I could solve this?
Yes, the line is between "signal" and "ground" of the port, usually the shortest possible path.
In your post #1 picture, you draw it on a feedline, that makes no sense.
