[Moved]Help needed: Interfacing 128x64 Graphic Display and 3x4 keypad with PIC16f877a
swapnil14327
Newbie level 5
Newbie level 5
Hello Guys,
I need help regarding Interfacing 128x64 Graphic Display and 3x4 keypad with PIC16f877a
here i have connected Keypad to port B and LCD to port C and port D.
using the below Code
//this is KBD.c
#byte kbd = 6                  // on to port B (at address 6)
#define set_tris_kbd(x) set_tris_b(x)
//Keypad connection:
#define COL0 (1 << 5)
#define COL1 (1 << 6)
#define COL2 (1 << 7)
#define ROW0 (1 << 1)
#define ROW1 (1 << 2)
#define ROW2 (1 << 3)
#define ROW3 (1 << 4)
#define ALL_ROWS (ROW0|ROW1|ROW2|ROW3)
#define ALL_PINS (ALL_ROWS|COL0|COL1|COL2)
// Keypad layout:
char const KEYS[4][3] = {{'1','2','3'},
                                   {'4','5','6'},
                                   {'7','8','9'},
                                   {'*','0','#'}};
#define KBD_DEBOUNCE_FACTOR 33     // Set this number to apx n/333 where
                                                     // n is the number of times you expect
                                                     // to call kbd_getc each second
void kbd_init() {
char kbd_getc( ) {
   static BYTE kbd_call_count;
   static int1 kbd_down;
   static char last_key;
   static BYTE col;
   BYTE kchar;
   BYTE row;
   kchar='\0';
   if(++kbd_call_count>KBD_DEBOUNCE_FACTOR) {
       switch (col) {
         case 0   : set_tris_kbd(ALL_PINS&~COL0);
                    kbd=~COL0&ALL_PINS;
                    break;
         case 1   : set_tris_kbd(ALL_PINS&~COL1);
                    kbd=~COL1&ALL_PINS;
                    break;
         case 2   : set_tris_kbd(ALL_PINS&~COL2);
                    kbd=~COL2&ALL_PINS;
                    break;
       if(kbd_down) {
         if((kbd & (ALL_ROWS))==(ALL_ROWS)) {
           kbd_down=FALSE;
           kchar=last_key;
           last_key='\0';
       } else {
          if((kbd & (ALL_ROWS))!=(ALL_ROWS)) {
             if((kbd & ROW0)==0)
               row=0;
             else if((kbd & ROW1)==0)
               row=1;
             else if((kbd & ROW2)==0)
               row=2;
             else if((kbd & ROW3)==0)
               row=3;
             last_key =KEYS[row][col];
             kbd_down = TRUE;
          } else {
             ++col;
             if(col==3)
               col=0;
      kbd_call_count=0;
  set_tris_kbd(ALL_PINS);
  return(kchar);
when i am calling kbd_getc() function its not waiting for response on keypad;
and not showing me any number pressed on keypad
//This is main.c
#include <16F877a.h>
#include <STRING.H>
#include <stddef.h>
#include <stdlib.h>
#include <ctype.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP
#use delay(clock=20000000)
#use rs232(baud=9600, parity=N,stop=1,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#include <GLCD.C>
#include <KBD.C>
void main()
	char temp1[]= "LCD 128x64 Test";
	char temp2[]= "Hello World";
	char temp3[]= "Press * To clear";
        char s1[15];
        char s=0;
	int j=0;
	*s1 = NULL;
   	glcd_init(ON);
	kbd_init();
	printf("start \n\r");
	glcd_text57(0,0,temp1,1,ON);
	glcd_text57(0,8,temp2,1,ON);
	glcd_text57(0,16,temp3,1,ON);
	while(TRUE)
	        s=kbd_getc();
		sprintf(s1,"%c",s);			//convert character into array
	    	glcd_text57((0+j),30,s1,1,ON);       //adding to print the space to GLCD
		printf("%c \n\r",s);                       //data for RS232
		j+=10;
		delay_ms(250);
	}while(s!='1');
//code for GLCD.c
////                           GLCD.C                                ////
//// This file contains drivers for using a Hantronix HDM64GS12 with ////
//// an LED backlight. The HDM64GS12 is 128 pixles across and 64     ////
//// pixels down. The driver treats the upper left pixel as (0,0).   ////
//// LCD Pin connections:                                            ////
//// (These can be changed as needed in the following defines).      ////
////  * 1: VSS is connected to GND                                   ////
////  * 2: VDD is connected to +5V                                   ////
////  * 3: V0 - LCD operating voltage is connected from a 20k Ohm POT////
////  * 4: D/I - Data or Instruction is connected to B2              ////
////  * 5: R/W - Read or Write is connected to B4                    ////
////  * 6: Enable is connected to B5                                 ////
////  *7-14: Data Bus 0 to 7 is connected to port d                  ////
////  *15: Chip Select 1 is connected to B0                          ////
////  *16: Chip Select 2 is connected to B1                          ////
////  *17: Reset is connected to C0                                  ////
////  *18: Negative voltage is also connected to the 20k Ohm POT     ////
////  *19: Positive voltage for LED backlight is connected to +5V    ////
////  *20: Negavtive voltage for LED backlight is connected to GND   ////
////  glcd_init(mode)                                                ////
////     * Must be called before any other function.                 ////
////       - mode can be ON or OFF to turn the LCD on or off         ////
////  glcd_pixel(x,y,color)                                          ////
////     * Sets the pixel to the given color.                        ////
////       - color can be ON or OFF                                  ////
////  glcd_line(x1,y1,x2,y2,color)                                   ////
////     * Draws a line from the first point to the second point     ////
////       with the given color.                                     ////
////  glcd_rect(x1,y1,x2,y2,fill,color)                              ////
////     * Draws a rectangle with upper left point (x1,y1) and lower ////
////       right point (x2,y2).                                      ////
////       - fill can be YES or NO                                   ////
////  glcd_bar(x1,y1,x2,y2,width,color)                              ////
////     * Draws a bar (wide line) from the first point to the       ////
////       second point.                                             ////
////       - width is the number of pixels wide                      ////
////       - color is ON or OFF                                      ////
////  glcd_circle(x,y,radius,fill,color)                             ////
////     * Draws a circle with center at (x,y)                       ////
////  glcd_text57(x,y,textptr,size,color)                            ////
////     * Write the null terminated text pointed to by textptr with ////
////       the upper left coordinate of the first character at (x,y).////
////       Characters are 5 pixels wide and 7 pixels tall.           ////
////       - size is an integer that scales the size of the text     ////
////     * Note - The given text is character wrapped. If this       ////
////       function is used on a different size display, then change ////
////       the GLCD_WIDTH define appropriately.                      ////
////  glcd_fillScreen(color)                                         ////
////     * Fills the entire LCD with the given color.                ////
////        (C) Copyright 1996,2003 Custom Computer Services         ////
//// This source code may only be used by licensed users of the CCS  ////
//// C compiler.  This source code may only be distributed to other  ////
//// licensed users of the CCS C compiler.  No other use,            ////
//// reproduction or distribution is permitted without written       ////
//// permission.  Derivative programs created using this software    ////
//// in object code form are not restricted in any way.              ////
#ifndef GLCD_C
#define GLCD_C
#ifndef GLCD_WIDTH
#define GLCD_WIDTH 128    // Used for text wrapping by glcd_text57 function
#endif
#define ON  1
#define OFF 0
#define YES 1
#define NO  0
#ifndef GLCD_CS1
#define GLCD_CS1 PIN_C0   // Chip Selection 1
#endif
#ifndef GLCD_CS2
#define GLCD_CS2 PIN_C1   // Chip Selection 2
#endif
#ifndef GLCD_DI
#define GLCD_DI  PIN_C2   // Data or Instruction input
#endif
#ifndef GLCD_RW
#define GLCD_RW  PIN_C4   // Read/Write
#endif
#ifndef GLCD_E
#define GLCD_E   PIN_C5   // Enable
#endif
#ifndef GLCD_RST
#define GLCD_RST PIN_C3   // Reset
#endif
BYTE glcd_readByte(BYTE chip);
void glcd_writeByte(BYTE chip, BYTE data);
void glcd_fillScreen(int1 color);
const BYTE TEXT[51][5] ={0x00, 0x00, 0x00, 0x00, 0x00, // SPACE
                         0x00, 0x00, 0x5F, 0x00, 0x00, // !
                         0x00, 0x03, 0x00, 0x03, 0x00, // "
                         0x14, 0x3E, 0x14, 0x3E, 0x14, // #
                         0x24, 0x2A, 0x7F, 0x2A, 0x12, // $
                         0x43, 0x33, 0x08, 0x66, 0x61, // %
                         0x36, 0x49, 0x55, 0x22, 0x50, // &
                         0x00, 0x05, 0x03, 0x00, 0x00, // '
                         0x00, 0x1C, 0x22, 0x41, 0x00, // (
                         0x00, 0x41, 0x22, 0x1C, 0x00, // )
                         0x14, 0x08, 0x3E, 0x08, 0x14, // *
                         0x08, 0x08, 0x3E, 0x08, 0x08, // +
                         0x00, 0x50, 0x30, 0x00, 0x00, // ,
                         0x08, 0x08, 0x08, 0x08, 0x08, // -
                         0x00, 0x60, 0x60, 0x00, 0x00, // .
                         0x20, 0x10, 0x08, 0x04, 0x02, // /
                         0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
                         0x04, 0x02, 0x7F, 0x00, 0x00, // 1
                         0x42, 0x61, 0x51, 0x49, 0x46, // 2
                         0x22, 0x41, 0x49, 0x49, 0x36, // 3
                         0x18, 0x14, 0x12, 0x7F, 0x10, // 4
                         0x27, 0x45, 0x45, 0x45, 0x39, // 5
                         0x3E, 0x49, 0x49, 0x49, 0x32, // 6
                         0x01, 0x01, 0x71, 0x09, 0x07, // 7
                         0x36, 0x49, 0x49, 0x49, 0x36, // 8
                         0x26, 0x49, 0x49, 0x49, 0x3E, // 9
                         0x00, 0x36, 0x36, 0x00, 0x00, // :
                         0x00, 0x56, 0x36, 0x00, 0x00, // ;
                         0x08, 0x14, 0x22, 0x41, 0x00, // <
                         0x14, 0x14, 0x14, 0x14, 0x14, // =
                         0x00, 0x41, 0x22, 0x14, 0x08, // >
                         0x02, 0x01, 0x51, 0x09, 0x06, // ?
                         0x3E, 0x41, 0x59, 0x55, 0x5E, // @
                         0x7E, 0x09, 0x09, 0x09, 0x7E, // A
                         0x7F, 0x49, 0x49, 0x49, 0x36, // B
                         0x3E, 0x41, 0x41, 0x41, 0x22, // C
                         0x7F, 0x41, 0x41, 0x41, 0x3E, // D
                         0x7F, 0x49, 0x49, 0x49, 0x41, // E
                         0x7F, 0x09, 0x09, 0x09, 0x01, // F
                         0x3E, 0x41, 0x41, 0x49, 0x3A, // G
                         0x7F, 0x08, 0x08, 0x08, 0x7F, // H
                         0x00, 0x41, 0x7F, 0x41, 0x00, // I
                         0x30, 0x40, 0x40, 0x40, 0x3F, // J
                         0x7F, 0x08, 0x14, 0x22, 0x41, // K
                         0x7F, 0x40, 0x40, 0x40, 0x40, // L
                         0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
                         0x7F, 0x02, 0x04, 0x08, 0x7F, // N
                         0x3E, 0x41, 0x41, 0x41, 0x3E, // O
                         0x7F, 0x09, 0x09, 0x09, 0x06, // P
                         0x1E, 0x21, 0x21, 0x21, 0x5E, // Q
                         0x7F, 0x09, 0x09, 0x09, 0x76};// R
const BYTE TEXT2[44][5]={0x26, 0x49, 0x49, 0x49, 0x32, // S
                         0x01, 0x01, 0x7F, 0x01, 0x01, // T
                         0x3F, 0x40, 0x40, 0x40, 0x3F, // U
                         0x1F, 0x20, 0x40, 0x20, 0x1F, // V
                         0x7F, 0x20, 0x10, 0x20, 0x7F, // W
                         0x41, 0x22, 0x1C, 0x22, 0x41, // X
                         0x07, 0x08, 0x70, 0x08, 0x07, // Y
                         0x61, 0x51, 0x49, 0x45, 0x43, // Z
                         0x00, 0x7F, 0x41, 0x00, 0x00, // [
                         0x02, 0x04, 0x08, 0x10, 0x20, // \
                         0x00, 0x00, 0x41, 0x7F, 0x00, // ]
                         0x04, 0x02, 0x01, 0x02, 0x04, // ^
                         0x40, 0x40, 0x40, 0x40, 0x40, // _
                         0x00, 0x01, 0x02, 0x04, 0x00, // `
                         0x20, 0x54, 0x54, 0x54, 0x78, // a
                         0x7F, 0x44, 0x44, 0x44, 0x38, // b
                         0x38, 0x44, 0x44, 0x44, 0x44, // c
                         0x38, 0x44, 0x44, 0x44, 0x7F, // d
                         0x38, 0x54, 0x54, 0x54, 0x18, // e
                         0x04, 0x04, 0x7E, 0x05, 0x05, // f
                         0x08, 0x54, 0x54, 0x54, 0x3C, // g
                         0x7F, 0x08, 0x04, 0x04, 0x78, // h
                         0x00, 0x44, 0x7D, 0x40, 0x00, // i
                         0x20, 0x40, 0x44, 0x3D, 0x00, // j
                         0x7F, 0x10, 0x28, 0x44, 0x00, // k
                         0x00, 0x41, 0x7F, 0x40, 0x00, // l
                         0x7C, 0x04, 0x78, 0x04, 0x78, // m
                         0x7C, 0x08, 0x04, 0x04, 0x78, // n
                         0x38, 0x44, 0x44, 0x44, 0x38, // o
                         0x7C, 0x14, 0x14, 0x14, 0x08, // p
                         0x08, 0x14, 0x14, 0x14, 0x7C, // q
                         0x00, 0x7C, 0x08, 0x04, 0x04, // r
                         0x48, 0x54, 0x54, 0x54, 0x20, // s
                         0x04, 0x04, 0x3F, 0x44, 0x44, // t
                         0x3C, 0x40, 0x40, 0x20, 0x7C, // u
                         0x1C, 0x20, 0x40, 0x20, 0x1C, // v
                         0x3C, 0x40, 0x30, 0x40, 0x3C, // w
                         0x44, 0x28, 0x10, 0x28, 0x44, // x
                         0x0C, 0x50, 0x50, 0x50, 0x3C, // y
                         0x44, 0x64, 0x54, 0x4C, 0x44, // z
                         0x00, 0x08, 0x36, 0x41, 0x41, // {
                         0x00, 0x00, 0x7F, 0x00, 0x00, // |
                         0x41, 0x41, 0x36, 0x08, 0x00, // }
                         0x02, 0x01, 0x02, 0x04, 0x02};// ~
// Purpose:       Initialize a graphic LCD. This must be called before any
//                other glcd function is used.
// Inputs:        The initialization mode
//                OFF - Turns the LCD off
//                ON  - Turns the LCD on
// Date:          5/28/2003
void glcd_init(int1 mode)
   // Initialze some pins
   output_high(GLCD_RST);
   output_low(GLCD_E);
   output_low(GLCD_CS1);
   output_low(GLCD_CS2);
   output_low(GLCD_DI);                // Set for instruction
   glcd_writeByte(GLCD_CS1, 0xC0);     // Specify first RAM line at the top
   glcd_writeByte(GLCD_CS2, 0xC0);     //   of the screen
   glcd_writeByte(GLCD_CS1, 0x40);     // Set the column address to 0
   glcd_writeByte(GLCD_CS2, 0x40);
   glcd_writeByte(GLCD_CS1, 0xB8);     // Set the page address to 0
   glcd_writeByte(GLCD_CS2, 0xB8);
   if(mode == ON)
      glcd_writeByte(GLCD_CS1, 0x3F);  // Turn the display on
      glcd_writeByte(GLCD_CS2, 0x3F);
   else
      glcd_writeByte(GLCD_CS1, 0x3E);  // Turn the display off
      glcd_writeByte(GLCD_CS2, 0x3E);
   glcd_fillScreen(OFF);               // Clear the display
// Purpose:       Turn a pixel on a graphic LCD on or off
// Inputs:        x - the x coordinate of the pixel
//                y - the y coordinate of the pixel
//                color - ON or OFF
// Output:        1 if coordinate out of range, 0 if in range
void glcd_pixel(int x, int y, int1 color)
   BYTE data;
   BYTE chip = GLCD_CS1;  // Stores which chip to use on the LCD
   if(x > 63)  // Check for first or second display area
      x -= 64;
      chip = GLCD_CS2;
   bit_clear(x,7);                                          // Clear the MSB. Part of an instruction code
   bit_set(x,6);                                            // Set bit 6. Also part of an instruction code
   glcd_writeByte(chip, x);                                 // Set the horizontal address
   glcd_writeByte(chip, (y/8 & 0b10111111) | 0b10111000);   // Set the vertical page address
   output_high(GLCD_DI);                                    // Set for data
   data = glcd_readByte(chip);
   if(color == ON)
      bit_set(data, y%8);        // Turn the pixel on
   else                          // or
      bit_clear(data, y%8);      // turn the pixel off
   glcd_writeByte(chip, data);   // Write the pixel data
// Purpose:       Draw a line on a graphic LCD using Bresenham's
//                line drawing algorithm
// Inputs:        (x1, y1) - the start coordinate
//                (x2, y2) - the end coordinate
// Dependencies:  glcd_pixel()
void glcd_line(int x1, int y1, int x2, int y2, int1 color)
   signed int  x, y, addx, addy, dx, dy;
   signed long P;
   int i;
   dx = abs((signed int)(x2 - x1));
   dy = abs((signed int)(y2 - y1));
   x = x1;
   y = y1;
   if(x1 > x2)
      addx = -1;
   else
      addx = 1;
   if(y1 > y2)
      addy = -1;
   else
      addy = 1;
   if(dx >= dy)
      P = 2*dy - dx;
      for(i=0; i<=dx; ++i)
         glcd_pixel(x, y, color);
         if(P < 0)
            P += 2*dy;
            x += addx;
         else
            P += 2*dy - 2*dx;
            x += addx;
            y += addy;
   else
      P = 2*dx - dy;
      for(i=0; i<=dy; ++i)
         if(P < 0)
            P += 2*dx;
            y += addy;
         else
            P += 2*dx - 2*dy;
            x += addx;
            y += addy;
// Purpose:       Draw a rectangle on a graphic LCD
//                fill  - YES or NO
// Dependencies:  glcd_pixel(), glcd_line()
void glcd_rect(int x1, int y1, int x2, int y2, int fill, int1 color)
   if(fill)
      int y, ymax;                          // Find the y min and max
      if(y1 < y2)
         y = y1;
         ymax = y2;
      else
         y = y2;
         ymax = y1;
      for(; y<=ymax; ++y)                    // Draw lines to fill the rectangle
         glcd_line(x1, y, x2, y, color);
   else
      glcd_line(x1, y1, x2, y1, color);      // Draw the 4 sides
      glcd_line(x1, y2, x2, y2, color);
      glcd_line(x1, y1, x1, y2, color);
      glcd_line(x2, y1, x2, y2, color);
// Purpose:       Draw a bar (wide line) on a graphic LCD
//                width  - The number of pixels wide
void glcd_bar(int x1, int y1, int x2, int y2, int width, int1 color)
   signed int  x, y, addx, addy, j;
   signed long P, dx, dy, c1, c2;
   int i;
   x = x1;
   y = y1;
   c1 = -dx*x1 - dy*y1;
   c2 = -dx*x2 - dy*y2;
   if(x1 > x2)
      addx = -1;
      c1 = -dx*x2 - dy*y2;
      c2 = -dx*x1 - dy*y1;
   else
      addx = 1;
   if(y1 > y2)
      addy = -1;
   else
      addy = 1;
   if(dx >= dy)
      P = 2*dy - dx;
         for(j=-(width/2); j<width/2+width%2; ++j)
            if(dx*x+dy*(y+j)+c1 >= 0 && dx*x+dy*(y+j)+c2 <=0)
               glcd_pixel(x, y+j, color);
         if(P < 0)
            P += 2*dy;
            x += addx;
         else
            P += 2*dy - 2*dx;
            x += addx;
            y += addy;
   else
      P = 2*dx - dy;
         if(P < 0)
            P += 2*dx;
            y += addy;
         else
            P += 2*dx - 2*dy;
            x += addx;
            y += addy;
               glcd_pixel(x+j, y, color);
// Purpose:       Draw a circle on a graphic LCD
// Inputs:        (x,y) - the center of the circle
//                radius - the radius of the circle
//                fill - YES or NO
void glcd_circle(int x, int y, int radius, int1 fill, int1 color)
   signed int a, b, P;
   a = 0;
   b = radius;
   P = 1 - radius;
   do
      if(fill)
         glcd_line(x-a, y+b, x+a, y+b, color);
         glcd_line(x-a, y-b, x+a, y-b, color);
         glcd_line(x-b, y+a, x+b, y+a, color);
         glcd_line(x-b, y-a, x+b, y-a, color);
      else
         glcd_pixel(a+x, b+y, color);
         glcd_pixel(b+x, a+y, color);
         glcd_pixel(x-a, b+y, color);
         glcd_pixel(x-b, a+y, color);
         glcd_pixel(b+x, y-a, color);
         glcd_pixel(a+x, y-b, color);
         glcd_pixel(x-a, y-b, color);
         glcd_pixel(x-b, y-a, color);
      if(P < 0)
         P+= 3 + 2*a++;
      else
         P+= 5 + 2*(a++ - b--);
    } while(a <= b);
// Purpose:       Write text on a graphic LCD
// Inputs:        (x,y) - The upper left coordinate of the first letter
//                textptr - A pointer to an array of text to display
//                size - The size of the text: 1 = 5x7, 2 = 10x14, ...
void glcd_text57(int x, int y, char* textptr, int size, int1 color)
   int i, j, k, l, m;                     // Loop counters
   BYTE pixelData[5];                     // Stores character data
   for(i=0; textptr[i] != '\0'; ++i, ++x) // Loop through the passed string
      if(textptr[i] < 'S') // Checks if the letter is in the first text array
         memcpy(pixelData, TEXT[textptr[i]-' '], 5);
      else if(textptr[i] <= '~') // Check if the letter is in the second array
         memcpy(pixelData, TEXT2[textptr[i]-'S'], 5);
      else
         memcpy(pixelData, TEXT[0], 5);   // Default to space
      if(x+5*size >= GLCD_WIDTH)          // Performs character wrapping
         x = 0;                           // Set x at far left position
         y += 7*size + 1;                 // Set y at next position down
      for(j=0; j<5; ++j, x+=size)         // Loop through character byte data
         for(k=0; k<7*size; ++k)          // Loop through the vertical pixels
            if(bit_test(pixelData[j], k)) // Check if the pixel should be set
               for(l=0; l<size; ++l)      // The next two loops change the
               {                          // character's size
                  for(m=0; m<size; ++m)
                     glcd_pixel(x+m, y+k*size+l, color); // Draws the pixel
// Purpose:       Fill the LCD screen with the passed in color.
//                Works much faster than drawing a rectangle to fill the screen.
// Inputs:        ON - turn all the pixels on
//                OFF - turn all the pixels off
// Dependencies:  glcd_writeByte()
   int i, j;
   // Loop through the vertical pages
   for(i = 0; i < 8; ++i)
      glcd_writeByte(GLCD_CS1, 0b01000000);     // Set horizontal address to 0
      glcd_writeByte(GLCD_CS2, 0b01000000);
      glcd_writeByte(GLCD_CS1, i | 0b10111000); // Set page address
      glcd_writeByte(GLCD_CS2, i | 0b10111000);
      // Loop through the horizontal sections
      for(j = 0; j < 64; ++j)
         glcd_writeByte(GLCD_CS1, 0xFF*color);  // Turn pixels on or off
         glcd_writeByte(GLCD_CS2, 0xFF*color);  // Turn pixels on or off
// Purpose:       Write a byte of data to the specified chip
// Inputs:        chipSelect - which chip to write the data to
//                data - the byte of data to write
void glcd_writeByte(char chip, BYTE data)
   if(chip == GLCD_CS1)       // Choose which chip to write to
      output_high(GLCD_CS1);
   else
      output_high(GLCD_CS2);
   output_low(GLCD_RW);       // Set for writing
   output_d(data);            // Put the data on the port
   output_high(GLCD_E);       // Pulse the enable pin
   delay_us(2);
   output_low(GLCD_E);
   output_low(GLCD_CS1);      // Reset the chip select lines
// Purpose:       Reads a byte of data from the specified chip
// Ouputs:        A byte of data read from the chip
   BYTE data;                 // Stores the data read from the LCD
   if(chip == GLCD_CS1)       // Choose which chip to read from
   else
   input_d();                 // Set port d to input
   output_high(GLCD_RW);      // Set for reading
   delay_us(2);
   output_low(GLCD_E);
   delay_us(2);
   delay_us(2);
   data = input_d();          // Get the data from the display's output register
   output_low(GLCD_E);
   return data;               // Return the read data
#endif
can any one please help me solve the problem..
any one having KS0108.c for 128x64 graphic LCD which will solve my problem.
the driver i used here for lcd is HDM64GS12 and the the module used is KS0108 so it is not working
i used the ks0108.c but it is only for 64x64 glcd. i want for 128 x 64 GLCD.
