Jester
Full Member level 6
- Joined
- Aug 18, 2012
- Messages
- 377
- Helped
- 7
- Reputation
- 14
- Reaction score
- 7
- Trophy points
- 1,298
- Location
- Activity points
- 4,754
I read a few application notes regarding effective ground planes, and they usually make a vague reference that the ground plane can be voided under the magnetic components.
I think the text is vague because it depends on the type of ground plane, this is how I'm interpreting what I have read, please let me know if I'm getting the gist of it or I'm misinterpreting what I have read:
- if there is a dedicated chassis ground plane, this plane would not be voided under the magnetics, as this plane would help capture and direct any noise from the magnetics to earth.
- An analog ground plane should be voided under the magnetics to minimize induced noise into the quiet ground plane.
My layout has a couple of SMPS regulators, as well as an analog portion that I'm attempting to keep as noise free as possible. I have two dedicated ground planes, I'm using one for the SMPS ground, and the other for the analog ground, although the planes overlap each other for most of the board they only share a common connection at one point (at the battery negative terminal). Does this sound like a reasonable layout strategy?
I have intentionally not stitched the two grounds together with a bunch of vias so the SMPS ground current stays in the SMPS ground plane.
