can you use the .step param statement, for instance if your hex value is used to define the value of a bus signal?
there an example in eldo's documentation in the .step section:
.param pat="HX000"
.sigbus vplus[9:0]
+ VHI=vdd
+ VLO=0
+ BASE=DEC
+ PATTERN $(pat)
.step param pat list "HX001" "HX010"
.param pat="HX000"
.sigbus vplus[9:0]
+ VHI=vdd
+ VLO=0
+ BASE=DEC
+ PATTERN $(pat)
Can you please elaborate more on this? My problem is that I couldn't define the pulse time, etc with .step command! Seems that what you have mentioned only replace two values it does not sweep between two values, right?
Do you think this command works? Sweep from HX000 to HX0010 with a step of HX0001
.step param pat HX000 HX0001 HX0010
using a sigbus and a pattern is a good way to define your signal, but I'm sorry I'm not aware of any way to define the pattern itself with a for loop
the .step command involes multiple runs of the simulation (one with each value) but this is not what you want
if you're trying to avoid the inconvenience of writing all the values to be used (can be troublesome), can you use a script to generate a csv file containing the values you want to use? (this script can then have the for loop). The sigbus and pattern commands in Eldo can load a csf file for the pattern definition
I think you could use the PULSE function. Here's an example for 12 bit. For counting down from 0x7FF to 000 you'd have to reduce it to 11 Bits and may be change the bit order. No - not the bit order. I think it's enough to exchange vlo against vhi - and vice versa.
