Mutad0r
Junior Member level 3
So I'm making a processor just for the fun of it and in various situations I will have to select between outputs, for example, should the output signal be from the full adder, a logic shift or whatever else the processor has. I'm not entirely sure how to implement this.
At first glance you could use an AND gate to sort of "enable" a signal to pass through, but the problem is that a CMOS logic gate actively pulls the output to ground if it's set to 0. This is demonstrated in the following image.
I haven't gotten a solution to this so far, so halp.
What I basically need is to have a gate that allows the digital signal to pass through, but otherwise lets the output float freely, without pulling it up or down.
